Wiring diagram
Old Jan 15, 2006 | 08:30 PM
jellyphish97's Avatar
jellyphish97 is an unknown quantity at this point
Default RE: Wiring diagram
Sorry about the overdue response, but i have been having a ton of personal things going on, so anyways. Today i went to the auto parts store and got a Add-A-Circut, opened up the fuse box on the left side of the dash. I ran the ground to the door bolt and it all worked the way i wanted it to. I have a couple of questions, Where should i permenatly ground it at, i cant seem to find a good place or a place that will work. Also the radar sit just above the middle of the dash, so i need to know how to run the wire from the fuse box to the radar. The Add-A-Circut i got is basically a fuse the plugs in with a wire comeing out, then i tapped into that wire to the direct wire kit i have for my radar, so i don't void my warranty. so i need to go from inside the fuse box to the radar and a good place to ground it out at. Thanx!
Ron
Old Aug 4, 2007 | 06:53 PM
nocluejimbo's Avatar
nocluejimbo is an unknown quantity at this point
ORIGINAL: swartlkk
On the newer vehicles, you can switch a fuse location in the box to have the lighter work with only the ignition on. My Bonneville was setup to work only when the key was on which doesn't work so well when I'm trying to pump up tires with my little 12v air compressor. Switched around a fuse or two and now it is constant power. It should be stated in your owners manual.
Have you confirmed this in a late-model Blazer? I didn't see it anywhere in the 2002 manual. I would love this to work with both accessory outlets. Maybe my old Jeep just had me spoiled by allowing me to do so.
Old Aug 5, 2007 | 01:17 AM
Blazer's do not have that function.. Seems they stuck with the old circuitry in the S-series.
Old Aug 5, 2007 | 02:49 AM
ORIGINAL: swartlkk
Can I change the wiring so they do?
Old Aug 26, 2008 | 03:32 PM
Trikes17's Avatar
Trikes17 is an unknown quantity at this point
[quote]ORIGINAL: swartlkk
I'm assuming that you're going to put your radar detector up high. If so, you could just wire it up to the overhead wiring that's there. If you are going this route, let me know and I'll see if I can find some references for the wiring up there. There should atleast be a ground that you have up there leaving you to possibly have to run a power (RAP - retained accessory power) wire.
I am interested in wiring a radar detector directly to my overhead console. Is this a difficult job? Ideally, I would like the unit to turn on and off with the car so i was thinking about trying to use the overhead computer for my power source. I have a 2002 4x4 blazer. Any advice? Thanks in advance.
Old Aug 26, 2008 | 07:44 PM
Please create a new thread. This thread is ancient.
phxjosh
Oct 30, 2013 10:03 AM
raptorman
19
Jan 14, 2010 10:21 PM
bob_elder
Nov 1, 2009 11:34 PM
1989Blazer269
Oct 26, 2006 12:15 AM
chris
Dec 6, 2004 12:47 AM
