Won't fire when cold - no codes or anything
Old Jan 17, 2011 | 01:32 PM
Tinted's Avatar
Tinted is on a distinguished road
Default Won't fire when cold - no codes or anything
so when it's cold and i try to start the truck at first all it would do is make clicking sounds, like click, click, click coming from under the hood when I turn the key. then on the second or third try it will turn over, fire up and die.
sometimes it will start and other times it takes a few tries to get it to turn over and actually run.
there are no codes.
also when this happens, the back glass unlatches on its own. weird.
i wanted to hear some of your opinions before i start blindly dumping money into it. I can take a few good guesses - cap, rotor, ect sensor. what do you guys think?
Old Jan 17, 2011 | 02:09 PM
rriddle3's Avatar
Originally Posted by Tinted
...also when this happens, the back glass unlatches on its own. weird...
This can be symptomatic of a dying battery. Have you had it tested?
Old Jan 17, 2011 | 02:49 PM
Tinted's Avatar
thank you for your suggestion, i was thinking the same. the battery seems to do fine under the load tho.
please keep ideas comin
Old Jan 17, 2011 | 03:17 PM
95Jimmy's Avatar
95Jimmy is on a distinguished road
Make sure all the battery connections are clean and making a good connection. Definately sounds like the battery.
Old Jan 17, 2011 | 08:45 PM
Tinted's Avatar
i hope its just the batt
also sometimes the TCCM just does not turn on when this happens
Old Jan 20, 2011 | 01:41 PM
old skool luvr's Avatar
i was going to suggest having the starter tested, which is what it sounded like @ first, but the electrical glitches is obviously a voltage problem.
how was the load test done? it'll make a difference on the outcome.
what about the wiring between the battery & the truck? i'm refering to all of the connections coming from the battery (positive & negative).
Old Jan 21, 2011 | 07:46 AM
Tinted's Avatar
its really weird, while trying to start the truck and while the engine is turning over (before it actually fires) the back hatch actuator produces that "unlocked" click with every revolution of the engine.
soooooooooooooo strange.
Old Feb 7, 2011 | 01:14 PM
Tinted's Avatar
new battery seems to have solved this problem.
Old Feb 7, 2011 | 09:53 PM
good to hear.
abadinalbany
Apr 16, 2011 11:31 AM
tall_ish
Nov 20, 2010 09:05 PM
bigjoewebb
Jan 27, 2009 09:36 AM
mikeesho1
Oct 26, 2007 12:31 AM
drperry
Jul 4, 2007 04:25 AM
