won't idle
Old Aug 7, 2021 | 03:40 PM
  #31
GeorgeLG's Avatar
OK. Again can you see the TPS value in your scanner?
George
Old Aug 7, 2021 | 03:42 PM
  #32
Oldladystrailrig's Avatar
Oldladystrailrig is on a distinguished road
No I don't think I am able to.
Old Aug 7, 2021 | 03:49 PM
  #33
GeorgeLG's Avatar
OK then same exact set up. +5V ref, -5V return and a signal wire out. The sensor is a variable resistor and the voltage should smoothly swing between 0 and around 4V with key on engine off and sweeping the throttle back and forth. Same drill, check power, check ground, check output voltage.
George
Old Aug 7, 2021 | 03:51 PM
  #34
GeorgeLG's Avatar
Start with everything hooked up key on engine off and monitor the voltage output while sweeping the throttle back and forth. 1-4V and smooth?
George
Old Aug 7, 2021 | 03:52 PM
  #35
GeorgeLG's Avatar
At the sensor that is by back probing or jumping the connector.
George
Old Aug 7, 2021 | 03:53 PM
  #36
GeorgeLG's Avatar
Sorry, 1-4V.
George
Old Aug 7, 2021 | 04:02 PM
  #37
GeorgeLG's Avatar
Wire colors should be signal (dk blu), +5V ref (gray), -5V return (blk).
George
Old Aug 7, 2021 | 05:03 PM
  #38
Key on engine off .7V across sensor output (blue) and - return (black) with no throttle and 4.5v at WOT. Moves smooth and steady
Old Aug 7, 2021 | 05:31 PM
  #39
GeorgeLG's Avatar
The P0122 code is set when the TPS sensor output drops below 0.1V so we have not reproduced the fault yet.
Do the same TPS output measurement with the engine idling and try some slow smooth rpm changes.
Measure the voltage at +5V ref and -5V return with everything connected, once with key on, engine off and once while idling.
George
Old Aug 7, 2021 | 05:35 PM
  #40
Back to the map sensor issue for a second. I still have the fused jumper across 5v ref and sensor output. I figured I try to clear the p0107 code map sensor low voltage but it's not clearing. I checked voltage across 5v ref and 5v return with key on engine off and I have 5v like I'm supposed to. But when I start the engine it's dropping to 0v. This same exact issue is happening with the tps also
