wont starrtt!!
Old Aug 20, 2008 | 10:28 PM
mike53980's Avatar
mike53980 is an unknown quantity at this point
Default wont starrtt!!
First i had a problem starting my truck usally after it sat for a while, so i changed the starter, seemed to help my truck start, then replaced the battery and then all of a sudden after a week of driving; i try to turn it over and i get nothing, engine doesnt attempt to turn over or anything. just maybe a clicking? cant tell if thats from ignition switch or not...pleasee helpp
thankkss
Old Aug 21, 2008 | 07:14 AM
Default RE: wont starrtt!!
The ignition switch is a good possibility, but lets start with the basics.
When you say it doesn't start, does it still turn over? Does it even attempt to fire?
If it turns over fine, but will not fire, I would start off by checking the fuel pressure. Fuel pumps are a known weak point in these trucks.
Old Aug 21, 2008 | 09:25 AM
mike53980's Avatar
Naw it wont attempt to fire, when I turn the key forward i get nothing; I have a 99 blazer wit 100k and i put a starter from a 03 blazer wit 21k on it , do you think that could of had something to do with it and maybe the starter just went out?
Old Aug 21, 2008 | 10:44 AM
So it does not turn over (starter motor spinning the motor). Ok, then I would be checking to make sure that you are getting power to the starter when you cycle the key.
Did you bench test the starter that you installed?
Old Aug 21, 2008 | 12:15 PM
mike53980's Avatar
What do you mean by bench test ? All i know is i bought it and worked good for about 2 weeks and then one mourning went to leave and bam got nothing lol, is there away to test if its a bad starter or if its something be4 the starter in the ignition?
thankss
Old Aug 21, 2008 | 12:20 PM
So it worked for a bit... By bench test, I mean to actually apply voltage to the starter to energize it before installation. Since it worked for a bit, then gave up, I might be inclined to say that you need to check over all of your work. Maybe you didn't get a wire as tight as necessary and it has worked loose. If you are good at removing the starter, then you could remove it again and bench test it to determine if it is the starter or something further up the power chain.
Old Aug 21, 2008 | 01:12 PM
mike53980's Avatar
Alright, Ill have to do that but also i remember hearing somewhat of grinding noise when I would start it but it didnt seem to get worse or make it more difficult to start, worked perfect night before, you think the grindin noise could have played a part?
dj00140
May 20, 2013 06:37 PM
JimmyBlaze541
May 2, 2013 10:00 AM
MikeTastic
Aug 8, 2012 04:41 PM
slammed95blazer
Oct 27, 2010 07:24 AM
jetsmy
Aug 1, 2008 10:10 PM
