wont start after re doing intake gasket?
Old Oct 26, 2009 | 08:28 PM
c.andrew's Avatar
c.andrew is on a distinguished road
Default wont start after re doing intake gasket?
I have ninety six blazer, It started leaking coolant from the back of the engine, after doing some research, I figured out it was the intake manifold gasket.
did it myself, changed it, the leak is fixed, my distributer is lined u with the little arrow with the six on it, it has fuel ressure, when i ush the bleeder thing fuel skirts out, but it has sark, I ulled the no 1 sark lug and there is sark, and I still cant get it to start.
I get a little ut outta it but thats it.
any ideas lease hel
also im missing the letter that rhymes with zee and is another word for urine so bear with me
Old Oct 26, 2009 | 09:25 PM
Did you line the distributor up with the 6 by rotating the engine by hand before pulling it the first time? If not, then you should not have lined it up with the 6 after you affected the rest of the repairs. You should have lined it up with a mark made before pulling it the first time.
Old Oct 26, 2009 | 09:40 PM
c.andrew's Avatar
hmmmm no i did not...I just ulled it and the ut it back the way I could get it to fit then it wouldnt start so i read that it need to be in line with the v and i used a screw driver and lined u the oil um so i could get it to fit and so that it was in line with the v. like it said to do. when reading i didnt see where it said to do what u r say I shoulda done....so the big Q is what do i do to get it to start ideas?? thanks
Old Oct 27, 2009 | 04:46 PM
c.andrew's Avatar
ok so I found the article on this site about the distrubutor and getting the tdc and the timing getting the crank shaft alligned and then did all of what it said to do but still will not start...I sprayed starter fluid and it started for just a sec as long as there was starter fluid so maybe fuel issue??? and what might I check. it seems to have pressure could there be air in the line form taking the in take manifold off?....any ideas will help...everything worked fine before it started leaking coolant and I changed the intake gasket it has 70k on it so its got to be something ive done while doing the intake or have not done...any help would be so great
Old Oct 27, 2009 | 08:17 PM
Could be a fuel problem, but you won't know without doing a fuel pressure test. Air would be purged pretty quickly.
Old Oct 28, 2009 | 01:28 AM
bigdaddykane93's Avatar
bigdaddykane93 is on a distinguished road
why cant you type the letter P ?
talon2g
May 25, 2013 08:18 PM
leroysfishingteam
Sep 27, 2012 05:27 PM
dylan71
Apr 25, 2011 08:39 AM
jspafford
May 27, 2009 09:03 AM
brinriha
19
Apr 14, 2007 05:12 AM
