wont start at all
Old Nov 23, 2014 | 02:45 PM
miller.sarah's Avatar
miller.sarah is on a distinguished road
Angry wont start at all
i have replaced the fuel pump and fuel filter in the last six months to solve the same problem i am having now.
a few weeks ago, my 97 blazer began having troubles starting. turn the key and the starter engaged but the engine would not turn over. come back to it a few minutes later and it would start right up. now, it wont start at all. again, the starter is doing its job but the engine just wont turn over. i've been told it could be the fuel pump again but i can hear it working. ive been told it could be the distributor cap, or the o2 sensor. any other suggestions from you veteran blazer owners? i really would like to be able to drive again.
Old Nov 23, 2014 | 04:25 PM
cleburne red's Avatar
Have you done a fuel pressure test? If so, post up the results here. Just because the pump is running doesn't completely rule it out. It has to be making enough pressure to fire the injector off. Also, what brand pump did you buy? Sometimes cheaper brands can go out in six months or so.
Also, you could have a problem with the regulator and spider in the intake manifold. Do a pressure test, and we can better help you.
Old Nov 23, 2014 | 05:32 PM
How do we do a fuel pressure test? is moving the blazer required?
Old Nov 23, 2014 | 09:31 PM
burned's Avatar
burned is on a distinguished road
You need to hook up a fuel pressure tester to the test port just behind the throttle body. Pressure needs to be 60-66 psi with the key on engine off. Pressure must remain above 55 psi after the pump shuts off.
Old Nov 24, 2014 | 06:41 PM
Just about any auto parts store will let you rent a pressure test kit for free. Usually about $150 deposit or so.
Old Nov 24, 2014 | 07:38 PM
Red Sled's Avatar
Red Sled is on a distinguished road
Take the time to MAKE SURE you have 60# pressure. Then go from there
Old Nov 29, 2014 | 03:13 PM
Default new fuel pump
so we need a new fuel pump. the brand that was installed was airtex. it obviously wasnt good enough so what brand would be the best for this vehicle?
Old Nov 29, 2014 | 08:09 PM
07nhbpsi's Avatar
07nhbpsi is on a distinguished road
A delco or a Delphi.....only pumps that will hold up!!! Pricey yes, but if u can wait a wk either ebay , Amazon, or some other online retailer sell them fairly reasonable!!!!! Good luck
Old Nov 29, 2014 | 08:14 PM
burned's Avatar
If that Airtex was purchased after Nov 2013 it has a lifetime warranty.
If you don't mind replacing fuel pumps often, lol.
Old Nov 29, 2014 | 08:26 PM
Red Sled's Avatar
I got a Delco for 190 shipped Amazon
