ABS and brake light staying on???? "The Fix"
Old Jun 16, 2012 | 03:36 PM
Bertbart's Avatar
Bertbart is on a distinguished road
Default ABS and brake light staying on???? "The Fix"
My ABS and brake lights on the dash were driving me nuts. They were on they were off. I knew the brakes would stop the vehicle whether the ABS was working or not....but it really bugs me when things don't work as they should. I was going to send the module off to be repaired...I had it in my hand and about to head off to the post office and I thought since I'm going to send it off I might well try opening it up to look for something obvious. I had nothing to lose.
I wiggled the six round solenoid cylinders soldered to the module that slide over the pump rods on the pump housing. Three were loose.
I used a #8 torx to pull the aluminum cover off of the black plastic base. After all of the tiny screws are out you must use a single edge razor blade to cut through the gasket. It will not pry apart without cutting along the edge. After getting the pieces split this will expose the back of the circuit board where the solenoid cylinders are soldered to. I re-soldered both legs on each of the six cylinders using a digital, heat controlled, soldering iron. (didn't want to burn the board)
Put it back together and now the ABS and brake light on the dash light up when the key is turned on and then turn off as they should when cranked.
After checking there are no more codes popping up.
I suppose the solder joints break loose from vibration over time causing the intermittent problem.
Old Jun 16, 2012 | 04:24 PM
50lb_cat's Avatar
Good thinking! Did you use anything to seal the housing where it was cut after the solder? My neighbor is having the same intermitent ABS problem on his 97. Might have to give this a try!
Old Jun 16, 2012 | 04:38 PM
Bertbart's Avatar
Originally Posted by 50lb_cat
Good thinking! Did you use anything to seal the housing where it was cut after the solder? My neighbor is having the same intermittent ABS problem on his 97. Might have to give this a try!
As a matter of fact I did not put any sealer on it. When I cut the seam I cut it clean leaving sealer on both halves. I believe it will be OK. I guess I'll find out down the road aways. Cutting the seal would have been easier with a #11 exacto knife blade. I just had a single edge razor laying on my work bench...convenient and at hand. Good luck!
Old Jun 16, 2012 | 04:44 PM
GP1's Avatar
GP1
GP1 is on a distinguished road
I'm going to try this tonight... Hopefully it works.
Old Jun 16, 2012 | 04:53 PM
50lb_cat's Avatar
Thanks for the tips! Were definetly gonna giver it the ol' college try lol
steve72
Sep 1, 2014 11:41 PM
cory renner
Aug 2, 2012 12:54 PM
blanco36
Aug 22, 2011 07:31 AM
95redblazer
Mar 8, 2011 01:30 PM
jlucey2
Oct 23, 2010 12:37 PM
