-   Article Submissions/Discussions (https://blazerforum.com/forum/article-submissions-discussions-47/)
-   -   Broken Hazard Switch Repair (https://blazerforum.com/forum/article-submissions-discussions-47/broken-hazard-switch-repair-28309/)
Taymacjack Mar 5, 2009 07:37 PM
This is very inexpensive and easy fix for any S-series vehicle from 1995 and up.
All you need is a pair of needle nose pliers (or leatherman) and a replacement hazard switch.
A replacement hazard switch can be purchased at www.parts4chevys.com for under $20.00 shipped, or at GM dealership for under $12.00
The GM part number for the switch is 15174447.
It goes by the name "SW KIT HAZARD"
https://cimg7.ibsrv.net/gimg/blazerf...ee6172c4fc.jpg
chances are you had some ghetto setup like this to keep your hazard lights from constantly flashing.
https://cimg9.ibsrv.net/gimg/blazerf...ccecb75a4d.jpg
The switch is broken half-way off in the socket
https://cimg0.ibsrv.net/gimg/blazerf...0b8323d5da.jpg
Grab the edge of the switch and just yank it out. You may have to wiggle the plastic housing to get the broken switch completely out.
https://cimg1.ibsrv.net/gimg/blazerf...2244c2292d.jpg
The new switch and whats left of the old one.
https://cimg2.ibsrv.net/gimg/blazerf...8f0557a458.jpg
If there's any little pieces of plasic or other debris in the empty socket, now is the time to get it out.
https://cimg3.ibsrv.net/gimg/blazerf...ece796662f.jpg
This kit comes comes with a small tube of dielectric grease. Coat the lower section of the switch.
https://cimg4.ibsrv.net/gimg/blazerf...833d6a8dfc.jpg
juicy
https://cimg5.ibsrv.net/gimg/blazerf...bd85f377ed.jpg
Insert the new switch and you're done. Much cheaper than purchasing a new assembly.
Link to the Tech Article: Broken Hazard Switch Repair
Marcin Nov 28, 2009 08:52 AM
Hi.
How to remove hazard switch from multifunction assembly?
Regards, Marcin
swartlkk Nov 28, 2009 07:12 PM
What part of the description above didn't you understand...? Grab a hold of the switch and pull....
This picture shows it quite well and sentence under completes it:
Marcin Nov 29, 2009 06:04 AM
Thanks. I found on NHTSA page detailed information how to remove hazard switch. My problem was where to put screwdriver.
http://nhthqnwws111.odi.nhtsa.dot.go...8V231-9740.pdf
Regards, Marcin
swartlkk Nov 29, 2009 08:24 AM
Pictures are worth 1000 words, must be you need more...
If you read this post here and look at the pictures, you will see that a screwdriver is not used. Only a pair of needle nose pliers (well, in this case, they look like a Leatherman Super Tool, but that is besides the point).
If you really want to make this more difficult than it needs to be, tear apart your steering column and use the screw driver as shown in that document (or this one 98+ Hazard Switch Replacement - you could have saved yourself some time searching through NHTSA). It really is quite easy, but you probably won't believe me (or anyone else) until you get in there and actually try it.
Marcin Nov 29, 2009 01:48 PM
Hi
My hazard switch is no broken so I can not imagine how to remove it without screwdriver. I really tried to remove it and was not able to do it :(. Now I removed it and ordered new one. Hazard switch seems to be a source of noise from turn light flasher when turning swich is at 0 position. Is it possible?
Regards, Marcin
swartlkk Nov 29, 2009 03:07 PM
If it isn't broke, then it's even easier. Grab hold of it with pliers and pull. It'll pop right out.
As far as your problem, this is not the proper place to discuss your technical issues. If you have a question pertaining to steps in this article, that is one thing, but this thread is a discussion on this article only.
Marcin Nov 30, 2009 06:47 AM
Sorry for making discussion in not proper forum. My mistake.
Regards, Marcin
fordssuck Dec 5, 2009 09:20 PM
can i just pull it out and get another one monday or does it have to be there to keep the lights from blinking???:icon_musclecar:
swartlkk Dec 6, 2009 07:15 AM
You won't have any hazard, brake, or turn signals until you replace it, but it wouldn't hurt anything if it wasn't there.
