Front Differential Electric locking system
Old Apr 11, 2013 | 07:08 PM
roypai's Avatar
roypai is on a distinguished road
If you wanted to retain the front axle locking up when the T-case goes into 4 THIS will go into the spot that the vacuum switch comes out of.
I'm 99% sure THIS is the proper connector for the above switch.
Above parts found on rockauto under: 2001 Blazer - Electrical-Switch & Relay - 4WD Indicator Light Switch
Wire/Connector found under the same but in 'Electrical-Connector'
THIS is found under 'Drivetrain - 4WD Actuator Valve'
I emailed Dorman and they tell me THIS connector/wire will fit the part.
The parts ship from different warehouses of course so I'll get them whenever i happen to get other stuff but for $70 it'll be worth not having the damn vacuum lines plug up again
Old Apr 12, 2013 | 09:23 AM
lityjohn701's Avatar
lityjohn701 is on a distinguished road
How would you hook this up and how would it work?
Old Apr 12, 2013 | 11:44 AM
roypai's Avatar
Exactly the same as set out by the OP but instead of going to a switch in the cab those wires head down to the t-case and hook to the first part I listed
the '4WD Actuator Valve' I'm assuming has an internal vent rather than a vent stem like the K series solenoid the OP used
Old Apr 13, 2013 | 08:05 PM
Hey I got the part today and it works! But it doesn't release the 4x4 actuator it will pull it in all the way but it won't release it. You have to uplug the vacuum line to release the actuator? What's going on?
Old Apr 13, 2013 | 08:06 PM
xgiovannix12's Avatar
Did you put the line from the actuator on the vent side?
Old Apr 13, 2013 | 10:21 PM
I put the line that goes to the actuator on the side with only one port. Then put the vac supply on the bigger of the two port on the other side just like in your pic u made
Old Apr 13, 2013 | 11:06 PM
OH I made a mistake when I made the diagram... Nice catch. The line that goes to the actuator has to be on the vent side.
Edit: I will need to contact an admin to edit my original post for the updated diagram
EDIT2 :
FIXED DIAGRAM
Attached Thumbnails Front Differential  Electric locking system-vacsolenoiddiagram_zps1109092f.png
Old Apr 14, 2013 | 07:41 AM
Aww I see! Thanks for the quick reply! This is an awesome mod!
Old Apr 14, 2013 | 08:06 AM
Any time Sorry about the issue with the vacuum not releasing
Old Apr 14, 2013 | 08:19 PM
No problem were just humans! And I got it all hooked up then my4x4 actuator got a tear in it! It's like one thing after another with this thing!
