How to: Ghetto Electric to Manual 4X4 - DISCUSSION THREAD
Old Sep 11, 2013 | 08:34 PM
xgiovannix12's Avatar
Originally Posted by AndrewO1991
I've dont this before when my encoder motor went out. It took effort but you shouldn't need a breaker bar or anything to move the peg. Make sure you are turning it the right way. Also, auto 4x4 and awd transfer cases work differently and I would NOT recommend doing this mod to them
I agree Ive converted my 233 tcase to a manual.
Lots of pictures in my build thread somewhere
Old Sep 12, 2013 | 07:41 AM
sky_blazer's Avatar
sky_blazer is on a distinguished road
i got the peg to turn and engaged 4x4 in the TC i only have the 3 button switch (no auto 4x4 or AWD)
Old Sep 12, 2013 | 03:10 PM
Thats fine you have a 233c tcase
Old Sep 13, 2013 | 03:27 PM
sky_blazer's Avatar
man i like your conversion on the manual TC i might have to try that. think it will work on a 2nd gen?
Old Sep 13, 2013 | 03:42 PM
Yep It will work.
Old Oct 19, 2013 | 07:57 PM
crash1781's Avatar
crash1781 is on a distinguished road
well this work on a 2000 blazer with 4 button?
never mind. must have missed the post about it not being recommended.
Old Feb 2, 2014 | 12:41 PM
Muddigger86's Avatar
Muddigger86 is on a distinguished road
Just done mine loving it. no need to remove the yoke tho for sure. you can take the three screws off the side that hold the incoder itself which is just the black plastic part and move it a little bit up and away and it gives you enough clearance for the rest of the motor assembly to be removed. However, the drive shaft not being removed while doing this may present a problem but I wouldn't know cause I just took mine out so I wouldn't have to deal with it in the way. I welded a couple 9/16 inch wrenches together for my shifter handle and yse a 9/16 allen wrench which I store in the console for the shifting handle on top of that so it only has to stick through the floor a couple inches. It's hardly noticeable.
Old Apr 16, 2014 | 05:58 PM
rcopes's Avatar
rcopes is on a distinguished road
Default Cable?
Has anyone thought about making the transfer case cable shifter, Not looking to reinvent the wheel if someone else has a better way to do it?
Just looking for a way to go completely manual,
Thanks for suggestions.
Old Apr 16, 2014 | 07:07 PM
I dont think there is a way of going cable with this setup.
Old Jun 20, 2014 | 04:57 PM
Horsehammerr's Avatar
Horsehammerr is on a distinguished road
Anyone have any Idea how to connect a cable directly to the axle shift at the front differential ? I know that's how the new Posi-lock cable works but, I can't see spending that kind of money for a simple cable.
