How to: Making a Cold Air Intake that works
*clicks like*
Using Gold foil or heat reflective wrap also would do a wonderful job of dispelling heat away from the intake. I am, of course, referring to Tavarish on Youtube's Turbo or Twin Turbo Lamborghini Gallardo setup.. won't link it to here because a Blazer is not a Lamborghini, but, works very well for directing heat elsewhere.
OP, you see noticeable performance gains from this nifty and awesome modification?
At this point, I'm almost finished with a frame-off restoration, and the truck is in the shop now getting a full paint job. When I get it back, I'll be doing the final finish work and tuning with HP Tuners. Considering that my "stock" airbox was 20 to 25 degrees above ambient, on an 85 degree summer day the IAT's would be at least 105, and that's huge. The next time I open my HP Tuners I'll find the spark advance table and how it's negatively effected by increased IAT. IIRC timing starts to get pulled beginning at around 80 or 85 degree outside air temperatures.
Overall modifications are mild, but in addition to the above, pretty much everything else that wears out on these things has been replaced, including new OEM fuel pump and upgraded OEM MPFI spider injection. A huge change was installing an 8.5 inch posi rear with different ratio, so overall performance is not even close to what it used to be.
BTW, I set my Ultra-Gauge to tell me the intake air temp and I can confirm that even after only a 5 minute ride with the outside air at 3'C (37'F) the inlet air temp was at about 9'C (48'F).
For a system that is supposed to bring in air from the outside, there must be a lot of heat radiated inside the engine compartment. I'll have to look up if there is any information on mileage and other performance improvements with using colder air.
