Remote oil line
Old Oct 8, 2009 | 02:12 AM
foxxie's Avatar
Sorry didn't mean to steal thread, just thought it might be helpfull.
Old Dec 12, 2009 | 08:26 AM
1994BlazerS10's Avatar
1994BlazerS10 is on a distinguished road
i need to do this to my 94, the lines are bleeding pretty bad
Old Dec 17, 2009 | 07:33 PM
jfnz24's Avatar
jfnz24 is on a distinguished road
Originally Posted by foxxie
End up doing my remote oil lines a couple of months ago & YAY no leaks.
This is what I ended up doing. Went to the local hydraulic shop & bought
1x meter of push-lok hose [400 psi].
8x 2 ear zp 17/20 crimps.
Removed the oils from the blazer &took pic of lines before I cut the old aluminium crimps of making sure I didn't cut the aluminium pipe.
Removed one pipe at a time, cut new pipe to length &put 4x 2 ear crimps on before connecting back to the aluminium lines. Made up a crimping tool out of a pair of vice-grips [vice-grips you can set a tension on them].
Crimped the first line on before removing the next line & then repeated process leaving one end of the hose uncrimped at the radiator end till I got the lines back into truck.
I had to find some seals for the aluminium blocks, went to local chev shop [Kiwiblazers neck of the woods] & they didn't know what they where as they sold it as a kit, had a look at what they had out the back & walked out with 4x sump plug seals [these where the same as what I took out].
Put new seals on & torque blocks up & crimped last line in place.
Home made crimping tool.
Lines 2x months later.
oil sump plug seals [old ones I took out]
Could you repost your pictures, as I am going to be doing this soon, and would like to use for reference. Thanks.
Old Dec 17, 2009 | 07:58 PM
CNYCountryKidd's Avatar
CNYCountryKidd is on a distinguished road
Originally Posted by Captain Hook
I went to my friendly neighborhood hydraulic hose builder, (NAPA) and bought four 1/2" compression to 1/2" hydraulic hose fittings, and 2' of -8 (1/2" I.D.) hydraulic hose. I had two hose assemblies made to the tune of about $60
Part #'s please! I work at NAPA so I could get em for dirt cheap :P Our discount is ridiculous! We pay 10% over what NAPA pays for stuff.
Old Dec 17, 2009 | 11:21 PM
foxxie's Avatar
Sure, no problem
Hope it helps.
Old Dec 22, 2009 | 01:27 PM
jfnz24's Avatar
Thanks. I'll be doing this after the holiday.
Old Jan 14, 2010 | 12:56 AM
ekiMMike's Avatar
ekiMMike is on a distinguished road
Forgive me for my insolence if im wrong but did u redirect the oil cooler lines?
Old Jan 22, 2010 | 02:29 PM
foxxie's Avatar
Put them back in the same way they came out, thats the beauty of digital cameras to take pics of things before you pull them apart.
Old Jan 23, 2010 | 07:52 AM
ekiMMike's Avatar
Ah i see
Old Feb 2, 2010 | 08:20 PM
99blklt4wd's Avatar
99blklt4wd is an unknown quantity at this point
Nice pics, I will have to try this cheap fix
