so you want a tire carrier on your 4 door?? - DISCUSSION THREAD
Old Mar 24, 2011 | 12:11 PM
  #91
Benedict1337's Avatar
probably alot easier to tighten them...
Old Mar 24, 2011 | 01:39 PM
  #92
mdehoogh's Avatar
Originally Posted by s14sh3r
Do the go through to the inside panel? If not, how the hell did you get your hands in there lol.
It's only bolted to the outside panel. I enlarged some of the existing holes near the top bolts and I cut my own access hole at the bottom to get to those bolts. Most of them have double stacked 2" fender washers against the metal. I have some flat bar stock that I might use to make a support bar that goes between the top and bottom bolt against the body panel.
This picture was from last week and I've since replaced the washers with larger ones and the better socket cap bolts.
Old Mar 24, 2011 | 03:37 PM
  #93
s14sh3r's Avatar
Damn. Can't nobody ever say you're afraid to cut **** up
Old Mar 24, 2011 | 06:37 PM
  #94
lol wow... I didn't cut near as much as you did, I only cut the top of the floor a little to get to the bottom bolts
Old Mar 24, 2011 | 07:22 PM
  #95
mdehoogh's Avatar
How did you guys get the middle bolts on then? Did you screw the nut down against the outside sheet metal or did you drill through more metal and use longer bolts?
Those sharp, jagged edges drew some blood rofl.
Old Mar 24, 2011 | 07:39 PM
  #96
s14sh3r's Avatar
I used short bolts on the middle ones like you did, but I used a small surgical forceps to put the washers and nut on. I used a lock washer, so I was able to tighten from the outside (barely) with the open end of a wrench. I broke the chuck in my dremel, or else I would have cut bigger holes.
Old Mar 24, 2011 | 09:27 PM
  #97
I used many socket extensions and flexible joints and a lot of patients to do mine...
Old Mar 25, 2011 | 12:53 PM
  #98
TripleBlackBlazer's Avatar
You're a doctor?
Old Mar 25, 2011 | 01:17 PM
  #99
Red 96''s Avatar
Originally Posted by TripleBlackBlazer
You're a doctor?
I thought the same thing after I read that ha! Why can't summer come quicker!!! I want to put my tire rack on so bad it's rediculous lol.
Old Mar 25, 2011 | 03:20 PM
  #100
mdehoogh's Avatar
Go for it man. You can knock it out in a day (especially if you have patients doing all the work for you lol)
I guess I'm not one to criticize though, I've had my carrier for months and just finally got around to putting it on
