165 Db
Old Jun 30, 2006 | 06:54 PM
95BlacerMississippi's Avatar
95BlacerMississippi is an unknown quantity at this point
Default 165 Db
i just bought more speakers i got 2 alphasonik 600j 12's the owner of Car Audio Invasions here in Picayune Ms says I am hitting 165db and the thing is i need a new alternator cus its not strong enough so i hit 165db with a power suply of 10.5V to the sub amp
he says i should upgrade my alt and then inter in to the usac in Baton Rouge La in a couple months.
He is thinking about hosting a comp here but the next closes one to me he said is his truck 157Db
I have an planet audio 1400d (1250w @2ohm) class d mono block amp
the 2 alphasonik 12's rated at 700w rms
a ported box total 4.33 cubic ft air space
a kenwood head unit with frunt rear and sub pre amp outputs.
an american pro 1.2 frad didital cap
american pro 600w 2 chanel amp for highs(no rear door speakers yet)
2 alphasonik tweets
2 pionerre 6.5 3way in frunt doors no dash speakers yet
(plan on going with all alphasonik speakers just wating for them to come in)
(use to have all Memphis aucio but i blue the 2 m3 12's i had)
plan on adding a 3way cross over and a 9 band eq with sub controll
anyone this this is an ok system?
Old Jun 30, 2006 | 07:28 PM
hillbillyinOhio's Avatar
Default RE: 165 Db
first off, I don't think there is a chance in hell that you are hitting 165 db, no offense, but I was running an APX 18 in a 10.5 cu ft(before displacement) ABC box tuned to 37 with 3300 watts through it and I was only hitting 155. and that was with 0 gaugee and a 200 ap alternator.
Old Jun 30, 2006 | 07:57 PM
XBlazer01's Avatar
XBlazer01 has a spectacular aura aboutXBlazer01 has a spectacular aura about
Default RE: 165 Db
Yea dont wanna sound like a jerkoff but I doubt it too. 2 L7's barely hit 165 and alphasoniks are THAT great.
Old Jun 30, 2006 | 08:01 PM
Default RE: 165 Db
well it just cracked my windshield
Old Jun 30, 2006 | 08:02 PM
XBlazer01's Avatar
Default RE: 165 Db
lol I've done that too. Its honestly not that tough to do that
PICS! I <3 stereo pics
Old Jun 30, 2006 | 08:07 PM
Default RE: 165 Db
CLASS D MonoBlock Power Amplifier
Signal-to-Noise Ratio
Frequency Response
Dimensions:
2250W x 1 Max Power (1 Ohm)
1750W X 1 Max Power (2 Ohms)
1200W X 1 RMS Power (2 Ohms)
800W X 1 RMS Power (4 Ohms)
125dB
20-250Hz
10-5/8”W x 2-7/16”H x 18-3/4”L
specs om my amp
as soon as i find my data cable for my cam i will put some pics up
Old Jun 30, 2006 | 08:08 PM
Default RE: 165 Db
PSW612J
12” ALPHA 600 SERIES SUBWOOFER
Cast Aluminum Machine Cut
“Alpha” Basket
Motor Assembly Heat Sink
Kevlar® Reinforced Composite
Balanced & Laminated Cone
TLTF J-Surround
Flat Progressive Rate Nomex®
Damper w/ Spiral-Woven Leads
8-Gauge Lug-Lock Input
& Output Terminal
Rated at 700 Watts RMS
88dB Efficiency
Frequency Response
of 30Hz to 500Hz
75 oz. Double-Stacked Magnet
Dual 4-ohm 2-1/2” Voice Coils
Mounting Dimensions
Depth: 6 1/2”
Through Hole: 10 7/8”
Diameter: 12 5/16”
Old Jul 1, 2006 | 04:43 AM
Binz316's Avatar
Binz316 is an unknown quantity at this point
Default RE: 165 Db
165? one of those see it to believe it, my last system was a lot more than that and I only hit 155.3 in the back of neon
Old Jul 1, 2006 | 06:33 AM
FatRyan's Avatar
FatRyan is an unknown quantity at this point
Default RE: 165 Db
lol, im sorry man, but if you dont even know what your taking about, you DEFINATLY arent hitting 165Dbs. even on the AC, i highly HIGHLY doubt your hitting even close to that. it takes alot of work and knowledge to get that high. sounds like someones just pulling your string for a sale.
Old Jul 1, 2006 | 06:41 AM
XBlazer01's Avatar
Default RE: 165 Db
lol i would doubt a 165 at the port! and 700 watt sub......................... no sorry man [&:] Go slap that guy at the shop in the face.
