1998 blazer custom stereo
Old Mar 26, 2012 | 05:10 PM
jrb_fishy's Avatar
jrb_fishy is on a distinguished road
Default 1998 blazer custom stereo
ok so i have 2 12 kicker cvr 1000 rms jl amp now i have to add a second battery into my blazer problem is the only place i have room is the back where the subs are it needs to be vented is there a spot i can use that is already there i was thinking right at the rear break lights just making a special attachment to go there and vent need some help here guys
Old Mar 26, 2012 | 05:36 PM
bobby099's Avatar
bobby099 is on a distinguished road
well in my blazer i have the same year as yours i pulled the peice to cover your cargo spot and took out the jack and i installed my battery right there and it worked perfectly i wish i had pictures it was hidden so perfect.
Old Mar 26, 2012 | 06:53 PM
jrb_fishy's Avatar
that is wher i was looking but i need to find a way to vent it directly to the outside it is a full size battery the draw my system has is massive how did you solve this problem for the venting
Old Mar 27, 2012 | 01:19 AM
MTopper's Avatar
are you talking about adding a regular car battery as your secondary?
have you looked into doing the big 3 upgrade? a high output alternator? a larger under hood battery?
if yes to all those and still having issues, get a sealed agm battery for the back because they don't need to vent, they can be mounted any way except upside down and have more reserve than a regular acid filled battery than can spill inside your nice truck
Old Mar 27, 2012 | 06:47 AM
c.clark.24's Avatar
c.clark.24 is on a distinguished road
ive spilled acid in the back on mine. not pretty
Old Mar 27, 2012 | 07:52 PM
jrb_fishy's Avatar
i have a ho alternator already and i have upgraded my wireing already so its time to add a second batt and i did it already i found a gromet under the plastic surrounding your back hatch and have a costom made box for the batt to sit in if it does spill it wont go anywhere and its totally sealed
Old Mar 28, 2012 | 09:42 PM
MTopper's Avatar
the only reason i ask is because i had a JL 1000/1, 300/4 and 300/2 in my truck before i sold it with the big 3, 145 amp alternator and an upgraded under hood battery and never had voltage drop lower than 13.6 when sitting at idle with the brakes and headlights on.
good luck
teamrojasx2
Aug 27, 2011 05:55 PM
steveharvey
Apr 24, 2011 12:03 AM
evinrude
Sep 15, 2010 10:37 AM
butters
Jun 29, 2010 06:01 PM
lodragon85
Jul 27, 2006 12:13 AM
