2000 blazer sub add
i bought a cheap little dual 8in bandpass with built in amp i want to eliminate the two back speakers and use those wires to splice and run to an inline high to low adapter for low input .how should i go about this - 2000 4dr 4x4 4 dr delco -stock audio except for two polk 6.5 front door spks
any help would be awesome .....
ok so i finally got the high to low all wired - powered sub is all good ... except i hooked up the neg. cable and my factory delco shows no signs of life . [ let me mention i took it fully out ,contrmplating the idea of replacing ] but when i turn the key back off , for a split sec i see the loc . then nadda
??? ok there r 3 plugs on my 2000 blazer 4 dr 4x4
1. antenna
2.that double plug (main) to the right
3. the one right below the antenna . in wich i have no plug ?? am i over looking it . cause i have searched the entire dash area . ?? cant remember if there was a plug in that slot ya know 7 to 8 Dos equis and a skinny little fat smoke and sleep ..lol.. Help Plzz if able .
maybe i wil just go and get a new H/U ? dont really want to tho ??
1. antenna
ok well , it appears that i have just some how lost my display when key is on , but everything works and sounds amazing . when key is on acc. it displays everything lol and my fuel gauge is wack . anyone have any suggestions . i am impressed at the bass that this little gem has added to my blaz ...
PaulO2288
Apr 21, 2011 12:25 AM
rickyp3278
Mar 20, 2008 11:38 PM
brad
Sep 2, 2005 01:47 PM
