2002 Speaker Color Codes
Old Jul 5, 2005 | 11:51 AM
*TLR*'s Avatar
*TLR* is an unknown quantity at this point
Default 2002 Speaker Color Codes
Hey Fellas and Ladies, I am going to begin wiring up my PAC unit which converts the regular speaker wires to the RCA style outputs, for wiring my amplifier........my only question is, i am unable to find the color codes, i need the color codes for the right and left rear speakers, but if you guys have the right and left front and rear positive and negative, the whole nine yards would be greatly appreciated
Old Jul 8, 2005 | 07:19 PM
deliriousvisions's Avatar
deliriousvisions is an unknown quantity at this point
Default RE: 2002 Speaker Color Codes
this good for you?
WITH AMPLIFIER
RADIO HARNESS
Wire Function Color Note Fuse # Size Location
+12V DC Battery(Constant) Orange 19 15 amp In-panel fuse box
Switched Accessory Dk.green 24 10 amp In-panel fuse box
Ground Black
Illumination Gray
Dimmer Gray
Steering Wheel Control Wire Light green
Left Front + Tan
Left Front - Gray
Right Front + Light green
Right Front - Dark green
Left Rear + Brown
Left Rear - Yellow
Right Rear + Dk.blue
Right Rear - Lt.blue
AT SPEAKERS
Left Front Tweeter + Brown
Left Front Tweeter - Yellow
Right Front Tweeter + Dark blue
Right Front Tweeter - Light green or light blue
Right Rear Mid + Dark blue or brown
Right Rear Mid - Light blue or yellow
RADIO HARNESS
+12V DC Battery(Constant) Orange RDO BATT 19 15 Amp In-panel fuse block
Switched Accessory Dark green RDO IGN 24 10 Amp In-panel fuse block
Ground Black
Remote Turn On(output) Dark green
Illumination Gray
Dimmer Purple/white or white
Left Front + Tan Line level output
Left Front - Orange/black Front audio return
Right Front + Light green Line level output
Left Rear + Brown Line level output
Left Rear - Dark green/white Rear audio return
Right Rear + Dark blue Line level output
AMPLIFIER OUTPUTS
12V DC Battery Orange AMPF 20 25 Amp In-panel fuse block
Remote Turn On (input) Dark green
Left Front Mid + Tan
Left Front Mid - Gray
Left Front Tweeter + Black
Right Front Mid + Light green
Right Front Mid - Dark green
Right Front Tweeter + Light green
Right Front Tweeter - Purple
Left Rear Mid + Brown
Left Rear Mid - Yellow
AT SPEAKERS
Left Front Mid + Tan or brown
Left Front Mid - Gray or yellow
Right Front Mid + Light green or dark blue
Right Front Mid - Dark green or light blue
Right Rear Mid + Brown or dark blue
Right Rear Mid - Yellow or light blue
BASE SYSTEM
RADIO HARNESS
Ground Black
Illumination Gray
Dimmer Gray
Left Front + Tan
Left Front - Gray
Left Rear + Brown
Left Rear - Yellow
AT SPEAKERS
RADIO HARNESS
Ground Black
Illumination Gray
chevyblazer9588
Sep 15, 2011 01:11 AM
abadinalbany
Apr 16, 2011 11:31 AM
bigjoewebb
Jan 27, 2009 09:36 AM
mikeesho1
Oct 26, 2007 12:31 AM
drperry
Jul 4, 2007 04:25 AM
