2002 stereo help
Old Feb 22, 2010 | 10:32 PM
02LS64dr's Avatar
02LS64dr is on a distinguished road
Default 2002 stereo help
Hi im new to the forums, but i have a problem. I have a 2002 s-10 blazer LT, and i have tried both the metra 99-2003 and 99-2001 install kits and they dont seem to be wide enough for this application. Has anyone else encountered this problem and how do i fix it? When i put the kit in the truck, the mounting holes slide between the mounting holes in the dash and the radio and kit just slide back into the dark. Thanks for your time!
Old Feb 23, 2010 | 02:58 PM
02LS64dr's Avatar
Here is some pictures i took of the stock radio and the metra kit 99-2003 not fitting properly.
Attached Thumbnails 2002 stereo help-pics-lanes-eternity-104.jpg   2002 stereo help-pics-lanes-eternity-105.jpg
Old Feb 23, 2010 | 03:06 PM
lilwalker20's Avatar
lilwalker20 is on a distinguished road
dude i am having the same problems only i have a 2001 s10 LT blazer my problem now after getting the kit to fit is the wiring could u maube send me some pictures on how you wired it and what colors go where??
Old Feb 23, 2010 | 04:16 PM
deadbuzzard's Avatar
deadbuzzard is an unknown quantity at this point
the kit that you have pictured looks like it fits the other blazers that have the double din stereo. I believe years 2003-2005. so to fix that gap you would need the dash piece from those years or even many of the bravadas.
That is a newer thread with some pictures.
https://blazerforum.com/forum/showth...ghlight=double
Old Feb 23, 2010 | 05:05 PM
DSMayo's Avatar
DSMayo is on a distinguished road
I had the same problem when installing the stereo in my '02. Sonic Electronix sent me the wrong kit, then best buy sold me the wrong kit, finally I went to Car Toys and they gave me the right kit. Sorry I cant find it on their website, but it shouldn't have a pocket - just one hole for the radio..
Old Feb 23, 2010 | 05:40 PM
02LS64dr's Avatar
So far Ultimate Electronics has sold me 4 wrong kits, im about to give up.. and its the width that is the main problem, it fits up and down fine and i like the pocket, the kit is just not wide enough for the mounting holes and it slides down into the back with the mounting tabs attached and everything.
Old Feb 23, 2010 | 05:49 PM
if it holds it in there look for the bezal at the junk yard.
Old Feb 23, 2010 | 05:52 PM
02LS64dr's Avatar
the wiring you just match the colors on the wiring kit to the colors on the stereo wiring, also you say you got a kit to fit, what kit number did you purchase?
Old Feb 23, 2010 | 05:53 PM
02LS64dr's Avatar
its not held in there, it slides side to side when i turn corners and such because the mounting holes in the kits are not wide enough to screw into the dash.
Old Feb 23, 2010 | 08:06 PM
DSMayo's Avatar
I dug around and found that I'm using the Scosche GM1500B dash kit. As far as I know, this is the only kit that works on the '02 blazers unless you have the double DIN stock radio, then you would get to keep the pocket
