6-Speaker System Questions
Old Dec 19, 2008 | 11:10 AM
NTL1991's Avatar
NTL1991 is an unknown quantity at this point
Default 6-Speaker System Questions
Hello,
I have a quick question about the speaker setup for a 1997 Bravada with an aftermarket Sony headunit. The tweeters on the dash are blown out; I removed the two "regular" dash speakers from my 1997 S10 (4-speaker system) to install into the Bravada. Will the wiring for the tweeters allow enough power through for "regular" plate speakers to be used?
Thanks,
Nick
Old Dec 20, 2008 | 10:22 PM
NTL1991's Avatar
Default RE: 6-Speaker System Questions
So I installed the speakers and they work fine in the dash, but I don't have any door speakers working. After checking them, they are all there (4 x Polk db651s) but after disconnecting the wiring to them and testing with a set of Pioneer speakers I have, I get nothing. All the wires are connected to the head unit, an Alpine CDE-9843, and I even tried hooking up my old Panasonic head unit. I am guessing the previous owner had an amplifier hooked up to drive the 4 door-mounted speakers and left the tweeters connected to the head unit to be powered.
How can I track down where the amp would've been? I'd like to either put a cheap amp in it's place or just bring the speaker wires back to the head unit...
Any suggestions?
Nick
Old Dec 21, 2008 | 02:13 PM
PABlazer's Avatar
PABlazer is an unknown quantity at this point
a normal place for a amp mount would b on the back of the back seats... i would check under the carpet under the backs of the seats or even in the wheel wells for the wires... and if they r not that u will have to just run new wires to all ur speakers
Old Dec 21, 2008 | 04:36 PM
NTL1991's Avatar
I'll check for the speaker wires around those places. Where are the wires routed for the rear door speakers? I know the front door speakers run through the rubber door passage then behind the dash, but whats the best way to run the rear door speakers?
Old Dec 21, 2008 | 08:04 PM
PABlazer's Avatar
i just jump them all behind the deck... its the easiest... if there not there then i have no idea where to tell u to look...
c3478493
Feb 3, 2014 02:56 PM
liltittle62
Dec 26, 2010 03:55 PM
jrpx2
Jul 8, 2010 02:02 PM
cmaddox421
Apr 28, 2009 07:08 PM
RedBlaze
Aug 19, 2005 10:59 PM
