-   Audio/Video Electronics (https://blazerforum.com/forum/audio-video-electronics-8/)
-   -   93 Suburban stereo help (https://blazerforum.com/forum/audio-video-electronics-8/93-suburban-stereo-help-68652/)
InsanePyro Mar 4, 2012 05:01 PM
Well I finally got around to a new truck...'93 Suburban. The guy I got it from had a really crappy deck in it. So I get the dash panel off and find the guy duct taped the wires together http://chevroletforum.com/forum/imag...s/confused.gif So I figure he was just low on money. But upon further investigation I found that as far as I can tell the factory wiring harness is completely missing http://chevroletforum.com/forum/images/smilies/mad.gif The power for the deck was provided via a wire ran directly to the battery which I disconnected and set off the car alarm in the process. So I'm asking...how do I go about finding the remainder of the harness?
Granted I know she ain't a Blazer but from what I've seen alot of the wiring looks alot the same.
As always....thanks guys
warthogdriver Mar 4, 2012 06:16 PM
I think on the crutchfield website they have wiring info ....might help
InsanePyro Mar 4, 2012 07:17 PM
It seems like all they have are generic guides unless I buy something from them. And I think I'll end up needing almost a vehicle guide as I might have to do some digging behind the dash
pettyfog Mar 4, 2012 09:02 PM
1992-93 Chevrolet Suburban Stereo Wiring Information
InsanePyro Mar 4, 2012 10:52 PM
Again thanks for the reply but as I said....the factory harness is non existent...I need to know where to go hunting for the wires...
pettyfog Mar 4, 2012 11:31 PM
Let me get this straight.. because there's no factory connector and someone chopped em back, you think he totally stripped the wires out?
I doubt it very much.
As far as where to start looking for the wires.. are you really serious? I COULD be a condescending patronizing prick and tell you to start at the rear left taillight harness but I wont. If there was a radio in there, you got the speaker wires..so that's good.
Now all you need to find in the vicinity are constant power, acc power and the wire from the dimmer/dash lamps.
That's why the wires are color coded!!!!!!! You got fuses, you got color codes and presumably something to test for power with. If that isnt enough then what the hell is it exactly you want to know?
InsanePyro Mar 5, 2012 01:08 AM
No you read that right....he had wires running along the floor to speakers he had sitting loose in the truck...I think I found the front dash ones but as for the ones in the rear doors and ones above the tailgate I have no idea where to look
pettyfog Mar 5, 2012 05:57 AM
The point is .. in the factory harness the speaker wires are all bundled. Use an ohmmeter or an old phone handset battery to test which speakers. If they work, you'll hear them scratch and pop
Sounds like he ran all new wires but you said he had 'duct-taped' them. So what was taped?
I still dont get the problem. You cant own an old car... esp an old GM car.. and not own some kind of electrical tester.
InsanePyro Mar 5, 2012 07:23 AM
Yeah I've got a multimeter...and all he had was his deck and then his own wires ran from under the dash to each speaker he had hooked up....there is nothing behind the deck now that I removed all the loose wires. Down by the brake and gas pedal there is a whole jumble of wires though. I'm guessing its down there somewhere?
InsanePyro Mar 5, 2012 01:00 PM
Hey I found it! Whoever did this cut the whole harness off right above the gas pedal...now the question is the wires for the rear speakers...do they go to the ones in the roof above the tailgate or the ones in the second row of seating doors?
