All done :)
Old Jan 9, 2008 | 06:23 PM
cloak01ls's Avatar
cloak01ls is an unknown quantity at this point
Default RE: All done :)
ORIGINAL: bobditts
looks gret a tip for next time..... round all of the edges of the wood in the port and the port opening. It will greatly reduce the risk of port noise.
I was just about to say that...I design most of myboxes to use the minimum amount of port area. So if you dont roundover, you will probably have port noise...
Box looks real good though man, I know a lot of folks that dont to 1/2 as good as you on thier first box..Now you just have tocover it and your ready to rock!
Old Jan 9, 2008 | 06:40 PM
Zasder's Avatar
Zasder is an unknown quantity at this point
Quick question...I wanna do the wire install myself and save the bucks....
I know the basics
Amp to Batt
Amp to ground
Hu RCA cables to amp
sub to amp
am I missing anything? and also what goes where on my amp?
Old Jan 9, 2008 | 07:06 PM
blazinloud's Avatar
remote wire from the deck.....tells the amp when to turn on and off.
Old Jan 9, 2008 | 07:07 PM
cloak01ls's Avatar
Only thing you missed is the remote wire. This is the 12v signal that tells your amp when to turn on and off, there should be a remote wire coming out of your deck that you can tap onto and run back to the amp with your RCA's...
What everything is on your amp:
12+ = Power
GND = Ground
REM = Remote Turn-On
Is that what you were looking for or do you mean the dial settings and everything?
Old Jan 9, 2008 | 07:08 PM
Zasder's Avatar
Is that included when I buy the 4 gauge kit?
Also where do they hook up? I have a good understanding, just want to make sure so I dont mess something up or start a fire
I mean on the second image...
Do the speakers go into output or input? stuff like that like where does everything hook up too.
Old Jan 9, 2008 | 07:10 PM
cloak01ls's Avatar
ORIGINAL: Zasder
Most kits come with a 17-20ft. 16-18awg remote wire...
Old Jan 9, 2008 | 07:15 PM
Zasder's Avatar
Ok cool...
Also can you clear up the second image on what goes were?
Old Jan 9, 2008 | 07:25 PM
cloak01ls's Avatar
ORIGINAL: Zasder
Subsonic filter should be turned 'On'...RCA's from the deck go on the 'input' side, high level input is not used for your install, Remote bass **** is pretty self explanitory, and I dont think i should have to tell you which speaker wire goes where, lol...
Old Jan 9, 2008 | 07:28 PM
Zasder's Avatar
Ok thanks! I didnt know where they were input or output!
also after much reading the RCA cables must be on one side of truck, while power has to be on another...
Which side does the remote cable run with?
Old Jan 9, 2008 | 07:36 PM
cloak01ls's Avatar
For a bass amplifier, you can run RCA and Power down the same side of the vehicle, along with the remote wire...
