Amp?
Old Mar 9, 2007 | 06:21 PM
RCarp48's Avatar
RCarp48 is an unknown quantity at this point
Default Amp?
So I have a 975 watt Rockford Fosgate amp powering 2 12's 1000 watts peak and just lately when i play them loud for about 10-15 mins all of the sudden they we'll stop playing as loud as they were- Need Help
Old Mar 9, 2007 | 06:43 PM
hillbillyinOhio's Avatar
Default RE: Amp?
check your gains, check your ground,
Old Mar 9, 2007 | 08:56 PM
blazinloud's Avatar
Default RE: Amp?
I dunno bout that amp but when mine gets too hot it will cut it down 3dbs.
Also when everything is cold it runs alot more effeciently. As everything heats up effeciency goes down. Mine is quite noticably louder when cold.
Old Mar 10, 2007 | 01:49 PM
RCarp48's Avatar
Default RE: Amp?
What do u think of getting a 1600 watt crunch mono block amp for my subs- is this a good idea?
Old Mar 10, 2007 | 01:56 PM
Loud_01_Blazer's Avatar
Loud_01_Blazer is an unknown quantity at this point
Default RE: Amp?
what kind of subs do you have??
Old Mar 10, 2007 | 02:15 PM
RCarp48's Avatar
Default RE: Amp?
I have2 12's lanzars DVC- I was thinking about getting that crunch amp or this 2000 watt lanzar vibe,or would that be too much watts?? I was alsowondering what the difference was between a mono block amp and a regular 2 channel amp?
Old Mar 10, 2007 | 04:19 PM
Default RE: Amp?
not knowing the model number of the subs, kinda hard to know. Crunch is making better amps these days. LMK what model subs you have, and we'll look it up for you
Old Mar 10, 2007 | 05:45 PM
RCarp48's Avatar
Default RE: Amp?
Well right now im thinkin about gettin a 2000 watt lanzar vibe amp (Lanzar vibe266) and hooking it uo to my 2 12's lanzar DVC 1000 watt peak power (Max12D) is this a good setup- also its 2 ohm stable unbridged and i have my subs wired parallel- will this workout?
Old Mar 10, 2007 | 06:33 PM
Default RE: Amp?
I would wire them up to 4 ohms bridged.
Old Mar 10, 2007 | 11:27 PM
blazinloud's Avatar
Default RE: Amp?
or get a 1 ohm stable amp
