AMP/BATTERY Questions...
Old Nov 25, 2007 | 02:18 PM
RidnClean's Avatar
RidnClean is an unknown quantity at this point
Default AMP/BATTERY Questions...
I'm lookin to see how big of a upgrade I need on my 99 Blazer.
I'm going to be getting a 1500 Watt amp and I know that seems to be alot of the electrical side.
I'm 17 , so I'm kind of on a budget.
so info would be helpful.
Also what is the specs on the stock amp alt. and battery in the blazer?
thnx for your answers.
Old Nov 25, 2007 | 02:37 PM
Mr Blazer LT's Avatar
Mr Blazer LT is an unknown quantity at this point
Default RE: AMP/BATTERY Questions...
What amp do you plan to get? Is that power for the entire system or just subs? You'll most likely want to do the alternator first and the battery last. 1500 watts i'd see how the stock alternator handles it first and upgrade as necessary.
Old Nov 25, 2007 | 02:47 PM
RidnClean's Avatar
thats total
what type of alt should i upgrade to?
Old Nov 25, 2007 | 03:02 PM
blznlowxtreme's Avatar
blznlowxtreme is an unknown quantity at this point
i agree with mr blazer. just get it installed and see how your alt handles it, i have a 1500 watt amp on my stock alt and battery and it can handle it pretty good. i have been running it for about a year and just now starting to see some affects on it. you can check your local autoparts store and see what high out put alt they carry
Old Nov 25, 2007 | 03:17 PM
RidnClean's Avatar
sounds good,
thanks for input X
Old Nov 25, 2007 | 03:21 PM
no problem
Old Nov 25, 2007 | 03:25 PM
cloak01ls's Avatar
cloak01ls is an unknown quantity at this point
Is 1500 the "RMS" wattage or "Peak" Wattage?
Old Nov 25, 2007 | 04:01 PM
RidnClean's Avatar
well lets see.
2 800 watt RMS subs
1 1500x1 RMS amp
and i know that RMS is what its constently ran at.
so yeah
Old Nov 25, 2007 | 04:04 PM
you will be fine, mine is 1500 rms not peak so youshould be fine
Old Nov 25, 2007 | 04:08 PM
RidnClean's Avatar
k good.
also i had a question.
does rap sound better if its in a ported or sealed?
