amp hook up
Old Dec 28, 2006 | 12:01 AM
blazer123456789's Avatar
blazer123456789 is an unknown quantity at this point
Default amp hook up
ok i got a new amp and subwoffers for xmas my problem is i need to get the wire for the amp from the battery to the amp in the back of the car. i dont no where to send the wire through to get it inside the car the engine area it needs to go through on the passenger side if at all possible i
i have a 2000 2 door chevy blazer
if anyone can help me it would be appriciated
Old Dec 28, 2006 | 12:13 AM
hillbillyinOhio's Avatar
Default RE: amp hook up
look between where your feet would be as a passenger, under the carpet. there is a large grommet that is right there, the antenna wire goes through that same hole. just poke through with a screwdriver, being careful,a nd presto, wire to engine compartment. Make sure that you wire-tie the power wire away from the block or exhaust manifolds.
Tuck the wire under the carpet to beside the seats, pull up door sill, run wire under, push wire under molding/whatever is in your way. done.
take remote wire (thats hooked up to remote-turn on or power antenna on back of deck, and rca's across the knee bolster on drivers side, tuck under kist panel, door sill, and back to the rear of the truck. thats all
Old Dec 28, 2006 | 12:31 AM
thanks alot i wil try that out tommarow
blazenblazer
Mar 7, 2010 09:05 PM
stealth1998
Nov 11, 2009 02:08 PM
midnightryder
Aug 8, 2009 12:17 AM
madeforliving
Feb 17, 2008 11:07 AM
mudsliner
Mar 29, 2007 10:33 PM
