amp location
does anyone have any idea or pictures showing where i can put my amp. under the seats wont work its a little to big and i only think i can screw it onto the box.
RE: amp location
Theres really no place to mount an amp to factory panels and have it look good. I would say the only two options are screwed to the box or make an amp rack...
RE: amp location
is there room behind any of the panels that you could hide it?
RE: amp location
just drill it to the back because i heard its better if the amp is closer to thesubs
RE: amp location
I mounted mine to the box, simply because there is no where else to do it.
RE: amp location
on the other hand, constant vibration isnt good for anything.......Try to use some sort of shock absorber on each corner of the amp.
RE: amp location
whould anyone have pics of what there amp rack looks like?
RE: amp location
mine is a false floor (in the making) where the rear seat used to be. It wont help you much in your situation.
RE: amp location
I would just mount it to the box with some rubber risers on it to isolate the vibration...Most amps wont have a problem as long as the box is braced well, but I have had a few amps have internal parts fall off over time...
RE: amp location
just make an amp rack. Takes like 20 mins lol.
Never mount to the box. Rattling an amp with important components inside to power it is never good. |
| All times are GMT -5. The time now is 07:17 AM. |
