Amp location
Old Dec 6, 2008 | 03:22 PM
Hotfingers's Avatar
Hotfingers is an unknown quantity at this point
Default Amp location
I'm trying to find a good spot to mount a couple of amps in my 2000 2dr blazer. Under the front seat is no good because of the air vents. There's 2 little compartments in the back right behind the doors but it doesn't seem as if there would be good ventilation in there. I'm trying not to give up much space in the back. Anyone got any ideas?
Old Dec 6, 2008 | 04:44 PM
in4lo's Avatar
in4lo is an unknown quantity at this point
Default RE: Amp location
Mount them on the little things that fold down with the rear seats. They're sturdy enough, and will hold 3 or 4 amps easily.
Old Dec 6, 2008 | 04:57 PM
Hotfingers's Avatar
I thought about that but they didn't seem sturdy. Maybe I'll give it a shot.
Thanks.
Old Dec 7, 2008 | 12:45 AM
jagblazer01's Avatar
they are perfectly fine to mount to.....or you can take them off and mount directly to the rear seats
Old Dec 7, 2008 | 12:57 AM
PABlazer's Avatar
PABlazer is an unknown quantity at this point
i have my 1 amp and my cap mounted on those flaps... they r very sturdy.. its also really easy to get at when u fold down ur seats, and is also even easier to hide ur wires from there...
Old Dec 7, 2008 | 07:16 PM
cr8390's Avatar
cr8390 is an unknown quantity at this point
i have my sony 1300 watt amp and my cap mounted on the flaps as well its a really good spot and it dosent take up any extra space
Old Dec 26, 2008 | 01:19 PM
thoffman79's Avatar
thoffman79 is an unknown quantity at this point
i aso hmy amp mounted on there....thers only 1 problem. i have my box back there and the amp is kinda heavy and when you hit bumps..pretty big ones the amp smacks off my back and has created holes through the carpet on my box.. i would sugest mounting your amp on your box if your trying to save space.
Old Dec 26, 2008 | 02:04 PM
FlatTopFoley's Avatar
FlatTopFoley has a little shameless behavior in the past
one thing to remember tho is mounting on the box makes it all the more easy and faster for someone to steel.
Old Dec 26, 2008 | 02:26 PM
thoffman79's Avatar
also true...so thats why u get full coverage and it covers your system as long as you have everything mounted...cuz trust mei ve checked into it
Old Dec 26, 2008 | 04:23 PM
blazerbumpin's Avatar
blazerbumpin is an unknown quantity at this point
mount it to the back of your box
JohnBarJB
Sep 28, 2020 07:34 PM
zedartwo
Oct 13, 2010 05:29 PM
ocblaze
Jan 5, 2010 11:40 AM
bitbandit
Mar 19, 2008 05:43 PM
fla_blazer4x4
Dec 25, 2007 08:38 PM
