Amp Location
Old Dec 29, 2009 | 09:59 PM
ocblaze's Avatar
ocblaze is on a distinguished road
Yea thanks for all the pictures but I'm going to build a rack that will fit on the right side of the cargo area.
Old Jan 2, 2010 | 03:14 PM
Benedict1337's Avatar
I used to have mine mounted to the seats but I hated how it was a pain to put the seats down when I needed to load something. I think this is a much better way to do i haven't had any problems just screwed it in and all the wires are hidden pretty nice about the same trunk room if I didn't have them
Old Jan 2, 2010 | 11:49 PM
ocblaze's Avatar
Did you make a mount for them, what did you screw them into?
Old Jan 3, 2010 | 12:06 AM
Peco's Avatar
Peco is an unknown quantity at this point
I have a 2 door so I used the storage on each side of the rear seat.
Old Jan 3, 2010 | 10:12 AM
FlatTopFoley's Avatar
FlatTopFoley has a little shameless behavior in the past
do they get good air while locked up in there?
Old Jan 3, 2010 | 12:00 PM
Peco's Avatar
Haven't had a problem the last 2 years. They get air flow from the whole rear panel, I removed the "plastic pocket" that was in the cubbie hole. And when the door is shut it's not exactly air tight.
Old Jan 3, 2010 | 12:17 PM
I have screws just going into the plastic
Old Jan 4, 2010 | 01:19 PM
ocblaze's Avatar
Thank y'all for all the ideas, i will be mounting like Benedict 1337 most likely. I am hoping to win a bid on the amp i will use and if i do everything will go in in 2 weeks!!!
Old Jan 4, 2010 | 05:54 PM
bigkeith11's Avatar
bigkeith11 is on a distinguished road
i was wondering if there was any way to mount the amps under the back seats?
Old Jan 4, 2010 | 06:25 PM
zedartwo's Avatar
Its tight under there but depending on your amp, you could try. Go put your amp under there and fold the seat down and see if it clears.
