RE: amp question
ORIGINAL: 2001blazer ok thanks for the info moonwater it was helpfull ORIGINAL: FatRyan yeah, word, dogg. you dont need to buy at your local BB, just buy online. m00nwater is teh **** too. sorry,im really drunk...but m00nwater is still teh ****! WOOT!!! |
RE: amp question
ORIGINAL: m00nwater ORIGINAL: 2001blazer ok thanks for the info moonwater it was helpfull ORIGINAL: FatRyan yeah, word, dogg. you dont need to buy at your local BB, just buy online. m00nwater is teh **** too. sorry,im really drunk...but m00nwater is still teh ****! WOOT!!! |
RE: amp question
so let me get this straight if i have a 4 ohm dual voice coil sub i should be looking at the 2 ohm stats of the amp...or am i wrong...............cuz i just heard a dvc 4 ohm sub gets wired like its 8 ohms (confused)
RE: amp question
ORIGINAL: 2001blazer so let me get this straight if i have a 4 ohm dual voice coil sub i should be looking at the 2 ohm stats of the amp...or am i wrong...............cuz i just heard a dvc 4 ohm sub gets wired like its 8 ohms (confused) anyways, yes, if you have a 4 ohm DVC sub, you need an amp that puts out that 500w at 2ohms. with a 4ohm DVC sub, each voice coil has a 4 ohm load. and your options for wireing the coils are either series (8 ohm load) or parrallel (2 ohm load). and an 8ohm load is generally too high do achieve the desired power output from your amplifier. you could also, have each coil wired to a channel (on a 2 channel amp), but mono block amplifiers are best suited for subwoofers. also, if you did have a 2 channel amp and it had gain settings for each channel, you could not hook it up, because in order to not destroy the driver, the gains would need to be exactly matched and thats virtually impossible to do. so find yourself a nice mono block amp that does 400-600w continuous at 2 ohm. good luck |
RE: amp question
ok thanks fatryan u have been so much help i am really thankfull so that alpine amp would actually be perfect for my sub... the one that u showed me through the link....by the way im going to wire my sub parallel
RE: amp question
no problem, man. anytime you need help, just message me or IM me (Sweetass98Blazer), and ill do my best.
RE: amp question
Otherwise sell your gift certificates for a little less, if you can. That way you can buy from anywhere you want. Just make sure you can sell them all for a decent price.
RE: amp question
if u cant trade the gisft cards for cash, then go with the alpine mono amp.. im not sure on the model number (somethin-350) its rated @ 350 rms @ 2 ohms.. its more than enugh to push 1 type r.. my cusin was pushin 2 12s 500 watts total RMS.. amp pushed them with ease..
