Which amp should I buy
Old Feb 20, 2009 | 12:50 AM
Hotfingers's Avatar
Hotfingers is an unknown quantity at this point
Default Which amp should I buy
I've got a 2000 Blazer LS 2door. I just installed an Alpine ida-x100 and the S series 4x6, 6.5, and 6x9's. I was just looking for a few suggestions as to which amp I should get. I'd like to stick with alpine seeing as I've never had any problems with them in the past. Any ideas?
Old Feb 20, 2009 | 07:15 AM
jagblazer01's Avatar
Default RE: Which amp should I buy
are you looking for a 4 channel? and what is your budget?
Old Feb 20, 2009 | 08:16 AM
Hotfingers's Avatar
I'd like to get 1 amp to power all 6 speakers so I guess I'd need at least a 4 channel, but I want it to match up correctly so it's not over running the amp. Or is there a way to feed the doors and rears off the amp and run the dash speakers off the receiver? And I'd would like to keep it under $250.
Old Feb 20, 2009 | 08:48 AM
are the speakers you have components?
Old Feb 20, 2009 | 11:15 AM
Hotfingers's Avatar
No, and I do regret not getting components. I was trying to keep it as clean looking as possible. My wife doesn't mind a little customization, but not too much. As I understand it they are all 4ohm speakers and if I ran the fronts together it would be a 2ohm drain on the amp. Is that right? So obviously I need something that will work with that. I do have a MRP-F450 that I had in another car that I would use if possible. But I don't want to fill the back up with amps. I also have a SWR-1242D with an amp that I still have to build a box for, so I really would like to keep it to 1 amp for the fronts and rears and 1 amp for the sub. Thanks for your input by the way. This form wouldn't be as great as it is without people like you helping outknuckleheads like myself.
Old Feb 20, 2009 | 11:18 AM
Hotfingers's Avatar
I also forgot to mention, if it is important or not, that I also have a PXA-H100 ordered and should have it any day. I'm still trying to locate the mic and cd that goes along with it. Everyone who isn't charging more than $75 bucks for it is out of stock.
Old Feb 20, 2009 | 11:28 AM
Hotfingers's Avatar
I found an Alpine MRP-F250 on Craigslist that I can probably pick up for $90 but I'd have to grab it right away. Do you think that would work out. I'd like to not have to spend a lot more $.
Old Feb 20, 2009 | 11:42 AM
Slow down there man. Please wait for responses. If you need to add further information, do so by editting your last post rather than post consecutively...
Old Feb 20, 2009 | 12:38 PM
Hotfingers's Avatar
Sorry captain.
Old Feb 20, 2009 | 01:09 PM
ORIGINAL: Hotfingers
that amp should work nicely....its only gonna give you 50w per channel @ 2ohms though
