Amp to sub wire size?
Old Oct 13, 2011 | 07:44 PM
chris015's Avatar
Default Amp to sub wire size?
Purchased that box with 2 12" fosgate 250 rms subs and 1200 watt amp. The amp is matted to the top of the box and had 18 awg running to the subs. Seemed small and the 4gauge amp wiring kit i Purchased had 12 awg for the speaker wire and i switched it out. Subs sound much better. Is 12 good enough?
Old Oct 13, 2011 | 07:59 PM
coolasice's Avatar
coolasice will become famous soon enough
I never used anything bigger then 12 on speakers, should be fine
Old Oct 13, 2011 | 10:20 PM
altoncustomtech's Avatar
As a general rule, unless you're running several kilowatts of power at low ohm loads then 12 gauge will be adequate.
Old Oct 14, 2011 | 07:13 AM
bobditts's Avatar
bobditts is an unknown quantity at this point
you really dont need to use anything larger than the size wire of your tinsel leads. I usually use 14ga for low powered subs.
Old Oct 14, 2011 | 08:02 AM
Badmonkey32's Avatar
Badmonkey32 is on a distinguished road
12 is plenty, thats what i have on my sub and its rms is 500 watts.
JohnBarJB
Sep 28, 2020 07:34 PM
chris015
Jul 8, 2012 01:19 AM
DJ 4x4
Sep 26, 2011 09:44 PM
bubba181x1
Mar 12, 2008 02:05 AM
rick465
Aug 25, 2006 09:37 PM
