RE: Another post... Building kick panels :(
atleast $350 FGing isnt cheap to buy custom made. Its much easier and cheaper to do it yourself.
I think the only problem right now is that i dont have a router to make nice rings.... will a jigsaw work?
yes a jigsaw will work. You dont need a router - its just a nicety. I barely use my router for circles unless you will actually see them. Its a pain in the arse.
Okay.. im gonna try it. I've seen some people take the panel off and duct tape the floor then pour some resin to make a form... is this a better way than using the panel itself as a template to build off of?
Thanks |
Just as another option I think Q-Logic makes kick panels, check crutchfield.
ORIGINAL: Blazin_Jason Just as another option I think Q-Logic makes kick panels, check crutchfield. |
qforms are not worth the money. The plastic flexes a lot which effects the sound. Fiberglass is easy to repair should something happen.
just for you bud, i will post a pic or 2 of the start of my kicks later tonight in my build thread.
Lookin good so far bob... Have you tested to see if the foot brake will clear?
yep yep. otherwise I would have angled them MUCH differently. They are pretty much teh same design as the qlogic qform kicks but built much stronger.
