another problem...
Old Apr 6, 2007 | 09:07 PM
vagnozzi's Avatar
vagnozzi is an unknown quantity at this point
Default another problem...
New headunit, new problem. I'm not getting power to my driver side door and dash speaker. I just wrapped and crimped the connections so I'm almost positive they are not loose. Checked connections at the amp and they're tight. I really don't want to take my dash coveroff again, so any guesses what it could be?
Old Apr 6, 2007 | 10:23 PM
hillbillyinOhio's Avatar
Default RE: another problem...
If i am reading this right, you haave the door speakers running off an amp. sounds like either a channel bad on amp, head unit, or loose wire. easy test, take wires off the amp for that speaker, and grab a 9 volt battery. Touch the wires to the battery and if there is no wiring issues, you will hear the speaker pop. If it does, then its something with the amp. If it doesnt, there is a wiring issue somewhere between the amp and the speaker.
Old Apr 7, 2007 | 01:57 AM
nai0013's Avatar
nai0013 is an unknown quantity at this point
what are you running speakers off of?
Old Apr 8, 2007 | 02:50 PM
vagnozzi's Avatar
When I crimped the LF+/LF- wires on the harness to the speaker wire, I pulled the LF+ wire out of the harness. I slid it back in and its fine now. I'm running all speakers off a 80x4 amp. Everything is working splendid
Trb
Feb 3, 2015 09:41 PM
chrishorton74
Jun 2, 2010 09:03 PM
trukid21
Jul 11, 2007 03:02 PM
J_man01
Engine & Internal
Jan 5, 2007 08:49 PM
Jman
Mar 12, 2006 07:05 PM
