Antennae connection repair
Old Apr 19, 2010 | 07:22 PM
bradly2795's Avatar
bradly2795 is on a distinguished road
Default Antennae connection repair
So I was removing my stock headunit out of the way today so I could reach some wires with the ac unit. When I went to put the radio back in radio didnt work. Take the dash all back apart and realize the antennae wire isn't plugged in. I find the wire and go to plug it back in when i see the very tip is bent sideways. Great. So in short antennae connector is broken and i need a easy/cheap fix to repair it. Any help please?
Old Apr 20, 2010 | 08:52 PM
bradly2795's Avatar
Ok so since I've not gotten any replies to the question maybe someone can chime in with an idea that was given to me today. I was told by a friend that you can buy just the male ends for the factory radio and just solder/crimp that onto the wire and just cut off the old connector. Has anyone else done this before? I wouldn't mind that as it seems to be a very easy fix.
Old Apr 20, 2010 | 09:45 PM
zedartwo's Avatar
Seems like a good idea. Gotta find a stock on tho. The aftermarket are a bit bigger/smaller and wont fit.
I don't recommend just cutting the old one right off. Cut the rubber casing and see whats inside. If theres a few wires make sure the one you are replacing it with is the same. Thats about it. I'm sure its not too hard!
tzb05
TrailBlazer GMT360/GMT370 (2002-2009) Tech
Dec 16, 2009 12:02 AM
mohawks76
Performance & Brainstorming
May 24, 2008 09:42 PM
jmberman
Mar 13, 2008 08:58 AM
djkrash
Jan 8, 2008 03:23 PM
hoffy
Sep 18, 2007 07:30 PM
