Audiobahn A8001DT is this a good amp?
Old Nov 20, 2007 | 09:22 PM
SillyLittleBlazer's Avatar
SillyLittleBlazer is an unknown quantity at this point
Default Audiobahn A8001DT is this a good amp?
http://www.techronics.com/index.cfm?...roduct_ID=1430 $294 on amazon btw but is the class D circuit really all that better? I already have 2 10" dual voice coil 4 ohm impedence rated at 1000w max a piece, I will hook it up as a 1 ohm load 800w out of this amp http://rockfordfosgate.com/rftech/wo...p;woofer_imp=4 This would be a good amp to get right?
Old Nov 20, 2007 | 09:41 PM
hillbillyinOhio's Avatar
Default RE: Audiobahn A8001DT is this a good amp?
That amp will not put out that power, what are the actual subs that you are using. might be able to find a better amp for cheaper!!
Old Nov 20, 2007 | 09:50 PM
bobditts's Avatar
bobditts is an unknown quantity at this point
audiobahn is a cheap flea market brand that is only concerned about the appearance of their product. The amps are completely over-rated meaning that they will never produce their rated power unless they get struck by lightning.
Old Nov 20, 2007 | 10:06 PM
What would be a good 1 ohm impedence mono amp to get then, most amps I have found are 2 ohm
Old Nov 20, 2007 | 10:21 PM
mdehoogh's Avatar
the brand new Kicker WX10000.110kW WARHORSE should be good enough. its at 2ohm though. and, unfortunately, it requires 2 HO alts and kicker recommends8 800CCA batteries for optimal performance
lol
Old Nov 20, 2007 | 10:44 PM
http://www.techronics.com/index.cfm?...roduct_ID=3360 what about this amp? or this one http://www.techronics.com/index.cfm?...roduct_ID=7617
Old Nov 21, 2007 | 12:30 AM
bobditts's Avatar
how much power do you need? what subs are you powering and how many?
Old Nov 21, 2007 | 10:34 AM
blazinloud's Avatar
that kicker sx will destroy the pioneer and the audiocrap amps.
but you can still get a better deal than that.....
check out www.onlinecarstereo.com
http://www.onlinecarstereo.com/CarAu...roductID=16368
^^^cheap power, slightly over rated. probably closer to 1400rms
http://www.onlinecarstereo.com/CarAu...roductID=15528
more power^^^ and cheaper than the kicker sx
Old Nov 21, 2007 | 02:51 PM
blznlowxtreme's Avatar
blznlowxtreme is an unknown quantity at this point
i have a massive audio p1500.1 amp. it is 1 ohm stable. i dont know if you need that much power though
Old Nov 21, 2007 | 03:19 PM
and btw, the soundstream PCA line is overrated as well. prob closer to 1300
