RE: Which is the best Capacitor Brand?
Cloak is right about taking it in to a professional!! Otherwise the two wires you downgraded, you might need to put those back up to what they were!!! Other than that rechecking all connections, making sure you have solid grounds on all your grounds and that you have no open circuts that are touching at all!!!
While you're there getting your beefy alternator tested, test your battery as well... Most places should do that kind of thing for free...
If you make them remove the alternator for a bench test, you may get charged, though... A cap is more of a band-aid than anything else... It may temporarily cover a problem, but that's about it.. Why did you downgrade your big 3 wires? Having a high amp alternator will NOT damage your system... It doesn't put out 150amps all the time, it only supplies whatever is needed at the time, that's why they have a peak/constant rating, a lot like peak and RMS rating for your amps... |
ORIGINAL: drperry While you're there getting your beefy alternator tested, test your battery as well... Most places should do that kind of thing for free... If you make them remove the alternator for a bench test, you may get charged, though... A cap is more of a band-aid than anything else... It may temporarily cover a problem, but that's about it.. Why did you downgrade your big 3 wires? Having a high amp alternator will NOT damage your system... It doesn't put out 150amps all the time, it only supplies whatever is needed at the time, that's why they have a peak/constant rating, a lot like peak and RMS rating for your amps... |
what all are you running? the Leds inside and the cap and the amp? still should not be dimming that much if at all.
I have the 1200 wat amp, the cap, the 1200 watt Dual Subs with neon, the leds, the Optx LED tailgate light, and I also have some neons on the inside too. And I have some more extras planned for in the future.
ORIGINAL: S10Blazer I had downgraded the cable from the alternator to the battery because a friend had told me that the larger the wire, the more power it would drain from the battery. |
ORIGINAL: S10Blazer I had downgraded the cable from the alternator to the battery because a friend had told me that the larger the wire, the more power it would drain from the battery. ORIGINAL: S10Blazer My question is, could the 4 gauge wire instead of the 6 gauge wire, have caused the high output alternator to give me a low voltage? What else could cause a high output alternator to react that way. |
ORIGINAL: S10Blazer I have the 1200 wat amp, the cap, the 1200 watt Dual Subs with neon, the leds, the Optx LED tailgate light, and I also have some neons on the inside too. And I have some more extras planned for in the future. |
I draw WAY more power than that with the stock alternator and none of my lights hit.
My sub draws 300W RMS when cranked (Amp is 350W RMS) And when I turn on my 800 or so watts of lights, my needle barely moves, and never leaves the 14V line, unless I'm driving really slow and hit like 500 RPM, then it bogs down, but other than that, no issues... That's also with the stock AC-Delco battery The wire reccomendation of 6 guage is the minimum wire they need for optimum performance... Ask your friend where his flux capacitor is wired in :Dlol j/k |
Ok, then I won't even bother with the high output alternator. I'm going to take it to a car audio place to get the sound system checked out, and if that doesn't solve it, I might just go back to the electrician I went to. The thing is, I had gone to that car electrician about a year ago for the same problem, and he had told me to get either a second battery or a high output alternator. The car electrician had also said that the system was quite a load, and that therefore I should consider a better alternator or a back-up battery. And btw, could you guys just go over "the big 3" again, just so I could put it all back together again? I believe its a 4 gauge from the positive on the battery to the back of the alternator, a 4 gauge from the negative on the battery to the chasis, and a 4 gauge from the negative on the battery to the alternator bracket. Am I correct?
