best way to wire 2 12" Alpine Type R's & Mrp-m1000
Old Jan 10, 2011 | 02:55 PM
BAM1369's Avatar
BAM1369 is on a distinguished road
Default best way to wire 2 12" Alpine Type R's & Mrp-m1000
What up guys!
I was at the pawn shop after i washed my truck and saw a guy bringing in his system, so i checked it out and it was exactly what i was looking for. 2 12" Alpine Type R's (swr-1242d) and a Alpine (Mrp-m1000) amp. So after the shop told him what they would give him for it i offered him $30 more and he took it.
Man the pawn shop guy was pissed.
Anyways i have searched alot and thought i would just check here before i install them.
Is this the best way to wire them, for the most power?
Old Jan 10, 2011 | 07:46 PM
old skool luvr's Avatar
it al depends on how much power (RMS) they can safely handle. (not too framiliar with the Alpine products)
while my PG amp wasn't a mono amp, i had my two 12W6's wired up for 1 ohm, and they never even blinked @ it. but the amp sure did "sweat" under high load/volume conditions.
Old Jan 10, 2011 | 11:27 PM
Blazin_Jason's Avatar
Says that those subs are dual 4 ohm voice coils. So you will have to do it this way.
The other option is to wire them down to 1Ω, but that amp could be damaged and I would not recommend it. Wire it to 4Ω's, if that's not enough for you then you would need to upgrade to a new amp.
Old Jan 11, 2011 | 08:10 AM
BAM1369's Avatar
Subs are 1800w 600w rms and the amp is 1000w rms.
So is this the best way to wire them?
Old Jan 11, 2011 | 05:49 PM
bobditts's Avatar
bobditts is an unknown quantity at this point
all you have to do is g to the alpine website and look up the install manual for the amp. nuff said.
Old Jan 13, 2011 | 07:19 PM
blazinloud's Avatar
no current alpine amp is 1 ohm stable, that i know of. so your best option would be 2 ohms to get the 1000 watts but it looks like your screwed and theyll only get less than 250 each.
Old Jan 18, 2011 | 08:32 AM
BAM1369's Avatar
I traded for a hifonics hfi1000d, ran it to 1 ohm and now my **** bangs! Im gonna wait till i have a little more money and get another hifonics amp prolly the same one and run them both on 2 ohm witch would put them both at about 750 rms or just a little lower.
Old Jan 18, 2011 | 10:29 AM
blazinloud's Avatar
thats about what im running to each of mine in a big ported box and theyre still fine over a year later. this was right after i installed em, still needed tuning.
http://www.youtube.com/watch?v=UTZXyHq4B5o
Old Jan 18, 2011 | 03:21 PM
BAM1369's Avatar
I got lucky getting the new ones, they handle 600w rms. I fugure if i run my hifonics amps at 2 ohm, 750w rms that would be perfect and i'd get the most i can out of the type r's.
Old Jan 18, 2011 | 05:43 PM
blazinloud's Avatar
power ratings on subs are only recommendations lol if your smart with the volume **** you'll never have problems
