Big 3 Help
Old Jul 14, 2008 | 03:57 PM
Big Frost's Avatar
Big Frost is an unknown quantity at this point
Default Big 3 Help
Hey guys,
Im doing the big 3 and i want to make sure i have the wires correct before i hook anything up.
Also, the best place for the negative to ground is the bolt holding the battery onto the tray right? or is it somewhere else?
pic.
[IMG]local://upfiles/10794/5B6EE71AD6EB432D97BE4F7DD8E67770.jpg[/IMG]
Old Jul 14, 2008 | 04:52 PM
bobditts's Avatar
bobditts is an unknown quantity at this point
Default RE: Big 3 Help
plenty of threads on this topic already. Have you tried a search?
Old Jul 14, 2008 | 05:13 PM
Big Frost's Avatar
Yes but im finding conflicting info... neg to chassey or neg to frame? on a fuse...should i fuse the bat to alt? some how-tos say yes some say no..
Old Jul 14, 2008 | 05:27 PM
slowjoe6969's Avatar
slowjoe6969 is an unknown quantity at this point
Yes fuse the wire between the Alternator and Battery, the factory system has a fusible link in it, by running your wire directley from the back of to the alternator to the battery. You remove the fail safe and risk causeing damage. If I am correct the fusible link is only 30 or 40 amps.
With your grounding just replace your factory battery cable and ground it at the same points, and then run one from the negative post to the alternator bracket or somewhere on the block just ensure they are cleaned very well.
Old Jul 14, 2008 | 05:29 PM
bobditts's Avatar
big3 is as follows
ground #1 - batt to engine block
ground#2 batt to frame
#3 - Alt to batt (fused or unfused up to you. some cars come with factory lat fuses, some dont)
Old Jul 14, 2008 | 05:30 PM
bobditts's Avatar
big3 is as follows
Old Jul 14, 2008 | 06:14 PM
Big Frost's Avatar
I dont se how a fuse will make a difference because current flows directly thru there back and forth
Old Jul 14, 2008 | 09:33 PM
The power goes from the Alternator through the fuse then connects to your battery terminal. If you are planning on running a big draw from a system, I recommend fuseing it. It may also be required for certain stereo competitions also.
Old Sep 1, 2008 | 08:21 AM
getonerd's Avatar
getonerd is an unknown quantity at this point
so what size fuse should i get and what kind(anl,maxi,agu) or it dont matter and should
Old Sep 1, 2008 | 10:17 AM
neo71665's Avatar
The fuse is pointless
