big 3 upgrade
I did a search, found NOTHING on how to do it, I found multiple posts on people who have, but no instructions? where would I find this. I got a free sub from my cousin, going to put it in the jimmy, do not want to slack anywhere.
I hope you will use actual sub wire,and not a orange power cord. (seen it done so many times,its bad).
anyways,the big 3 is simple. you use some 4 gauge (or bigger). Run it from the + side of the battery to the alternator (follow the old wire,leave it connected as it doesnt hurt anything) Then grind you a nice shiny spot on the frame. or find a bolt,remove it,make the frame shiny under it and use it. But use some self tapping screws to secure the new ground from the battery to the frame. THEN replace the small ground wire from the battery to the motor. there u go. |
Sorry its from another forum but good info none the less!
Big 3 upgrade |
Originally Posted by chris015
(Post 536205)
anyways,the big 3 is simple. you use some 4 gauge (or bigger). Run it from the + side of the battery to the alternator (follow the old wire,leave it connected as it doesnt hurt anything) Then grind you a nice shiny spot on the frame. or find a bolt,remove it,make the frame shiny under it and use it. But use some self tapping screws to secure the new ground from the battery to the frame. THEN replace the small ground wire from the battery to the motor. there u go. Thanks guys! Another project for me to get done. :icon_goofygrin: |
I might have to do this soon! would help out my system in the truck significantly
(Post 536207)
People have actually used extension cords for power wire to the amp? Wow!
Yeah there are some not so smart people out there!! I am ordering the wire and terminals on ebay right now and I found enough 0 gauge wire and the terminals all for $33.95 shipped. Thats so cheap I don't understand why people don't just do things right?????
Its just lazy is what it is.
I have seen so many people wire things wrong, not use inline fuses at the battery, and their car starts on fire. I think spending the little extra money it costs to not have to buy a new car from a fire. |
Since we are on stereo subject, I know the rear doors on my jimmy have 6.5" speakers. Can that be modified to put a 6x9? or would I be opening up a can of worms?
I wish I could answer that question but I don't have a clue so if i tried to give you an answer it would be made up lol!! Good luck on getting it figured out though!!
| All times are GMT -5. The time now is 11:27 AM. |
