box design help
hey im going to be building a kind of custom box i want a ported box tuned two 32 hrz with the port facing back or aero ports? and the sub fireing up but i also want an amp drawer under neath is this an easy thing to do? also wanted to know the difference between an aero box port and a slot port which one would be better for this box? im going to be putting a 15 inch fi bl in here. i have about 38 inches in width and 34 in length its for a 95 chevy blazer 4 door it would be great if someone could draw me up a sketch or some designs just to get me started if not give me some more ideas thanks
[/align] |
RE: box design help
I have had 2 10" Rockford Fosgate He2 Subs in a custom AERO ported box. If you want stupid loud, I reccomend aero ports. With 2 10's and a 500rms Kenwood amp, I got a Db reading of 142.7
I also have made a slot port box and didnt like it as much as my aero ported box. The sound was a little more rough. |
RE: box design help
well whats involved in instaling aeros?
RE: box design help
I had 2 aero ports on the back of the box right behind the magnet of the subs. You'll need ( depending on the size) somthing to cut a round hole to fit them in. Mine were in two pieces so I cut the hole, screwed the opening in, and with the subs out, attached the other half. Some people glue them together, but are hard to get apart afterwards. I just used duct tape. It holds them together with no rattles and if you decide to take them out and use them in another box you can do so.
RE: box design help
ok so how are they tuned? and anyone have any ideas how i could build this beast of a box?
RE: box design help
It was really just a squae box. Ill send you an email with the picture of the car it was in, then maybe you could some how figure out the measurements.
Email adress? |
RE: box design help
I believe there's a bit more to designing a ported box than just making a square and cutting some openings in it...and I'm not familiar with all these technical terms...so what exactly is 'stupid loud'?
And remember people run entire businesses off box design...I wouldn't count on someone just 'drawing up a sketch' for you.. |
RE: box design help
I believe there's a bit more to designing a ported box than just making a square and cutting some openings in it...and I'm not familiar with all these technical terms...so what exactly is 'stupid loud'? And remember people run entire businesses off box design...I wouldn't count on someone just 'drawing up a sketch' for you.. |
RE: box design help
Here is what I had for 1 15" BL 1st gen blazer. External dimensions 37.25" wide, 17" deep, 16.25" high, 3/4" MDF with a double baffle flush mount, 2 4" PSP ports 14" long. So internal dimensions were 35.75x14x15.5 then minus sub and port discplacements. Sounded good to me. Info on how to determine port length here.
http://www.blazinjason.com/fibox2.jpg |
RE: box design help
For me, with the twoten inch subsstupid loud was 142.7 Dbs. You really could not sit in the car without ear plugs it was just way too loud. And I mean thats pretty damn good considering: 1 amp, no dynamat, 4 gauge wiring, and the car was off during the competition running straight from a stock battery.
I made the box custom with specs for the subs, I didnt just make a square box with two ports in it.:D |
