capacitor yes no?
Old Jan 8, 2008 | 10:01 PM
Tippman7641's Avatar
Tippman7641 is an unknown quantity at this point
Default capacitor yes no?
ok ihave a boss 1400 watt 2 channel 750rms ampo and two 12 pionner subs, today i was told by a couple of coworker that i would really benefit from addmin a capacitor, is thistrue/ wat will it relaly do for me???
Old Jan 8, 2008 | 10:05 PM
blazinloud's Avatar
Default RE: capacitor yes no?
what will it do? nothing more than suck more power from your charging system hence making it less effecient.
Old Jan 8, 2008 | 10:06 PM
cloak01ls's Avatar
cloak01ls is an unknown quantity at this point
If you like 10lbs paper weights than a capacitor is definately what you need
But seriously, a capacitor is a band-aid on a bullet wound. It will stop the bleeding momentarily but eventually youre gonna die. Better alternatives to capacitors are upgrading and adding batteries, upgrading you factory battery wiring to a higher gauge, or if things get really sticky, a high output alternator...
But, the fact is you need none of these things because your factory alternator and charging system will have no problem keeping up with the 500 watts your Boss amp will dish out...
Old Jan 8, 2008 | 10:07 PM
they said it would make it louder like a second battery or something, casue one guy had one said it was worth it but im not sure,i should be uprading to an optima battery soon as well, my current one always is about 12-14 constant(in that area)
Old Jan 8, 2008 | 10:11 PM
tonkpils's Avatar
tonkpils is an unknown quantity at this point
not worth it. i got one becuase im using it as a distro block also
Old Jan 8, 2008 | 10:12 PM
HA i knew they were wrong, thanks
Old Jan 8, 2008 | 10:16 PM
hey i cant complain about the boss i won two $100 gift cards to sears at a home show, so baiscly it was free, but do you think i might need one if i got a kicker amp, mephis, or audioban?
Old Jan 8, 2008 | 10:20 PM
blazinloud's Avatar
you never need 1
Old Jan 8, 2008 | 10:26 PM
cliro's Avatar
cliro is an unknown quantity at this point
agreed, stay away from them.
Old Jan 8, 2008 | 10:28 PM
k, that brings me to the question, why are they made?, like do they server a purpose thats usefull in a ceritan type of situation
