cb radio
hey i was just wondering what was the best way to hook up a cb radio and horn. the last time i did it the rubber around the power wire melted and the whole thing started smoking.
RE: cb radio
i had my cb power wire directly to the battery and then the ground was on the body mount under the drivers door. and i didnt have any problem but as far as the horn i couldnt answer that one.
jimmyboy |
RE: cb radio
the cb radio i wired the positive to the fuse box and grounded the negitive to the fire wall. if u dont want the stock horn then i would say just wire it with the stock wire but if not i would probaly wire it the same way as the cb but ive never wired in a horn
RE: cb radio
Make sure you fuse the radio.
RE: cb radio
thanks for all the help fellas. i will try and see what happens now.
RE: cb radio
to blazinrebel or whoever else: how did you connect it to the fuse box? could you possibly take picture or something. thanks tyler
edit: i currently have a cigarette plug on it. |
| All times are GMT -5. The time now is 07:39 AM. |
