choosing the right amp for my subs
Hi I have 2 10' kicker comp-vx and they are rated at 600 watts rms each. They are 4 ohm subs. Now i need to buy an amp and I am looking at the mtx ta7801 because it is rated 1200 watts rms but at 1 ohm. Is this going to be good enough or do I have to look at the 4 ohm rating of the amp? Help please thanks in advance.
Are they Single voice coil or Dual voice coil. I dont recall kicker making a SVC CVX...Im guessing they are Dual 4ohm subs. This means you can wire them to the amp at either a 1 or 4 ohm load...So if they are indeed dual 4 ohm subs, then that amp you are reffering to will work just fine...
ORIGINAL: carlo
they are dual voice coil so if they will work at 1 ohm then how do i have to wire them?
