choosing the right amp for my subs
Old Dec 18, 2007 | 07:36 PM
carlo's Avatar
carlo is an unknown quantity at this point
Default choosing the right amp for my subs
Hi I have 2 10' kicker comp-vx and they are rated at 600 watts rms each. They are 4 ohm subs. Now i need to buy an amp and I am looking at the mtx ta7801 because it is rated 1200 watts rms but at 1 ohm. Is this going to be good enough or do I have to look at the 4 ohm rating of the amp? Help please thanks in advance.
Old Dec 18, 2007 | 08:12 PM
hillbillyinOhio's Avatar
Default RE: choosing the right amp for my subs
you will have to look for an amp that does its power at 2 ohms.
Old Dec 18, 2007 | 08:14 PM
carlo's Avatar
O really so an amp that is rated 1200 watts at 1 ohm is not powerful enough? does anyone know or recommend any amps?
Old Dec 18, 2007 | 08:16 PM
cloak01ls's Avatar
cloak01ls is an unknown quantity at this point
Are they Single voice coil or Dual voice coil. I dont recall kicker making a SVC CVX...Im guessing they are Dual 4ohm subs. This means you can wire them to the amp at either a 1 or 4 ohm load...So if they are indeed dual 4 ohm subs, then that amp you are reffering to will work just fine...
Old Dec 18, 2007 | 08:20 PM
carlo's Avatar
they are dual voice coil so if they will work at 1 ohm then how do i have to wire them?
Old Dec 18, 2007 | 08:24 PM
cloak01ls's Avatar
ORIGINAL: carlo
You will have to wire them in parallel, which is running all of your positive's together and negatives together....give me a sec and ill find you a digram that will explain it much better than words can...
Old Dec 18, 2007 | 08:25 PM
cloak01ls's Avatar
carlo's Avatar
ok thanks alot
Old Dec 18, 2007 | 08:27 PM
cloak01ls's Avatar
No problem, that's what I'm here for...
carlo's Avatar
so basically you put the postive of both your subs into one postive of your amp and both of your negative from the two subs into one negative on your amp?
