A couple of questions..
Old Jul 8, 2009 | 12:51 AM
roflwaffle08's Avatar
roflwaffle08 is on a distinguished road
Exclamation A couple of questions..
I have a 1998 Blazer, LT, 4door, 4wd.. Couple of questions here..
First of all, I've heard mixed reviews of the speaker sizing in the rear doors.. is it 5 1/4 or 6 1/2? I took off the door panel and they looked a bit smaller than 6 1/2 but I didn't measure or anything..
Secondly, a question regarding the speakers themselves..
I recently replaced my two front door speakers and my Head Unit.. When doing this, I found out that my rear and dash speakers weren't working - even before replacing everything up front. The 4 doors look like they are wired in series (connected as rear speakers in the wiring harness), and there are tweeters in the dash (connected as front speakers in the wiring harness). The rear speakers and the tweeters do not work at all. Is it because they are just blown? I'm not sure of a decent speaker test to tell if this is the issue or not, I'd like to make sure it isn't a faulty connection instead before buying some new ones..
Thanks!
Old Jul 8, 2009 | 03:36 PM
bandidolenny's Avatar
I replaced all 4 door speakers with 6 1/2" pioneers from wal-mart... my dash tweeters haven't worked since I've owned the blazer but it sounds just fine to me.
Just replace your rear door speakers but you may wanna test the wiring with a known working speaker first.
Old Jul 8, 2009 | 03:58 PM
Well I took out the rear speakers today and they look like they are 5 1/4" instead of 6 1/2.. ordered some new dash speakers and rear speakers today, tested the speakers on a different audio source and I got nothing out of them so problem solved I think, I'll post back when I put them in.. thanks
Old Jul 10, 2009 | 07:21 PM
Well, everything worked when I put the new speakers in.. the wiring is definitely strange though.. Front Left, Rear Left and Rear Right are all using the same wires (Yellow + Brown) while the 2 dash speakers and the Front Right speaker have their own dedicated wires..
The 5 1/4 that I put in the rear were significantly smaller than I thought they would be, seems like they are supposed to be 6" speakers, not 5 1/4" or even 6 1/2".. hmm.. I made them fit though so it doesn't matter too much..
PiKapp
Jan 20, 2007 01:45 AM
mx416
Dec 24, 2006 08:31 PM
Jackal
Engine & Internal
Dec 6, 2006 10:40 PM
jpap
Oct 25, 2006 01:22 AM
Benado
Oct 23, 2006 12:16 PM
