dead
Old Jan 23, 2008 | 04:19 PM
blznlowxtreme's Avatar
blznlowxtreme is an unknown quantity at this point
Default dead
monday after work my subs were fine, went to school and came out and they were dead, and about 15 minutes of driving they just started working and work the rest of the night, but the next morning dead again and haven't worked since. i cant figure out whats wrong. i checked my rca's and they were fine but replaced anyway and still nothing, am is on but subs are dead, i checked the connections at the head unit. anybody know anything else to try, i need these working asap.
Old Jan 23, 2008 | 04:24 PM
EuroGoldLS's Avatar
EuroGoldLS is on a distinguished road
Default RE: dead
Could be the wiresinside the box....
Old Jan 23, 2008 | 04:29 PM
hillbillyinOhio's Avatar
Default RE: dead
pm'd
Old Jan 23, 2008 | 04:43 PM
jagblazer01's Avatar
Default RE: dead
check ur grounds...maybe one came loose. is ur amp powering on?
Old Jan 23, 2008 | 05:39 PM
Default RE: dead
i have aldeady checked wire inside box everything is hooked up, and yes amp is getting power.
Old Jan 23, 2008 | 05:51 PM
Default RE: dead
you may have a blown channel......take a DMM in probe you speaker wires coming out of the amp....play a test tone or something and see if your getting any output from the channel
Old Jan 25, 2008 | 03:52 PM
Default RE: dead
well i attepted to the DMM trick and the dam thing just started working, has not worked since monday but when i turned it on to test worked fine, i guess i will try again wendsday if its not working then
Old Jan 25, 2008 | 04:03 PM
Default RE: dead
hahaha interesting lol
Old Feb 15, 2008 | 09:23 PM
Default RE: dead
ok well i finally got time to check into this problem, and it turns out my amp is the problem, it went into prtect one night so when i got home i was just going to un plug the power from it and when i touched it i actually burned my hand bad enough that it left a mark on there for about a week, i have dropped it off at the audio shop and he is going to try to get them to replace it but if not the will fix it because its still under warrenty
Old Feb 16, 2008 | 05:17 PM
thegr81's Avatar
Default RE: dead
Thats cool as long as it gets fixed for you and your back to bumping the tunes!!
94s10blazin
Aug 10, 2013 01:00 PM
trettifire
Oct 3, 2009 08:48 PM
rriddle3
Aug 26, 2007 04:38 PM
hdlogistics
Nov 29, 2005 08:39 PM
brownblazer
Sep 12, 2005 06:55 PM
