dead r12 system to r134 conversion dead in water help ac techs
Old Jul 26, 2013 | 08:41 PM
94s10blazin's Avatar
94s10blazin is on a distinguished road
Default dead r12 system to r134 conversion dead in water help ac techs
bought a very clean 94 lta2 this year... so nice i'm converting to r134. had a newer rebuilt 07 r12 setup well it ate itself metal shavings everywhere!!! so went to convert to r134 bought new r4 compressor and to get warranty bought new accumulator, orifice tube ,flush ,oil ,and low cutoff sensor ..
PROBLEM start here
last part to put on was accumulator and vacuum down surprise evaporator out fitting wont fit! stock oem evap off both brazers wont fit it .. accumulator is toughone brand like the rest of all the new parts . had another new accumulator from 4seasons same thing evap out wont tread but hose from compressor fits both accumulators.. wtf....!!
anyone have this problem?
any help appreciated
Old Aug 6, 2013 | 06:53 AM
93S10TahoeLT's Avatar
BUMP for this..
I too have a messed-up AC system and want it to run right and cool well.
Old Aug 6, 2013 | 08:30 PM
ussexplorer's Avatar
ussexplorer is on a distinguished road
Default Not sure why
I'm not sure why it won't fix but from my understanding you pretty much need 100% new system. Hoses, compressor, etc, etc.
From my undestanding the comrpessor has to be bigger to make up for the fact the r134a is not as efficient as r12 was. Also that the hoses leak the r134a due to being smaller molicules.
Wow that was a bad spelling. Anyway you can look it up online. To bad the compressor died like it did. You could have converted too freeze12 and keep the r12 system in place.
Thanks,
Josh
Old Aug 7, 2013 | 01:43 PM
whent to stealership and got stock accumulator put some retro fit fitting on it. new r134 accumulators they sell don't work with oem evaporators don't know why . running cold ac.explorer no way i could convert the compressor blew apart splitting the case and sounds like a bag o nut when you shake it... how much is freeze 12 i only spent 15 bucks on r134 for the whole system + 170 for compressor and stealership 40 $ accumulator
Old Aug 10, 2013 | 01:00 PM
TheRemedy's Avatar
TheRemedy is an unknown quantity at this point
Anyone have an average price on R134a conversion from R12? I have the old R12 system which worked with 134a for a while, but is no longer working now. Could I do the work myself and have the shop drain and refill?
hypertek
Jun 16, 2011 10:46 PM
Ryanmatt135
Jan 29, 2011 10:48 AM
Dakota_Don
Apr 26, 2010 12:25 PM
2klt
May 16, 2009 01:09 PM
peegh
Apr 22, 2007 11:47 AM
