digital cluster
Old Dec 9, 2006 | 03:01 AM
91 Streeter's Avatar
91 Streeter is an unknown quantity at this point
Default digital cluster
i have a 91 blazer with the crappy cluster and i was wondering if i could change it to a digital cluster? i know the plugs in the back are different but the wires to each plug should be the same right? so would i be able to splice the wiring harness into the new plug for the digital cluster? are there any wiring diagrams? thanks
Old Dec 9, 2006 | 03:53 AM
XBlazer01's Avatar
XBlazer01 has a spectacular aura aboutXBlazer01 has a spectacular aura about
Default RE: digital cluster
http://www.cyberdynegauges.net/
check them out.
i have there voltmeter and it has yet to fail me
Old Dec 9, 2006 | 04:01 AM
thanks but i was asking because i already have a digital gauge cluster from an 89 with same size motor and trans and everything
Old Dec 9, 2006 | 04:08 AM
XBlazer01's Avatar
oooooohhhhhhhhhhhhhhh blah
my bad bro. (late/long night)
you might be able to splice in. I'm not sure how well it'll work tbh.
I could look around and let you know though
Old Dec 9, 2006 | 05:01 AM
thanks. the splicing wont be a problem i do good work i just hope i can match all the colors[:'(]
Old Dec 11, 2006 | 02:56 AM
tore apart my dash today and the plug on the digital cluster has one more wire on it than the stock one. they all have the same colors i think there might be an extra ground on the digital one? any help? suggestions?
Old Dec 11, 2006 | 03:36 AM
XBlazer01's Avatar
extra ground?
Just ground it!
should work like a charm then
Old Dec 11, 2006 | 04:25 AM
haha i think the digital cluster has two black wires thats why i said that. when i get the time im gonna rip the whole dash apart and splice the wires and see what happens haha
Old Dec 11, 2006 | 01:49 PM
XBlazer01's Avatar
Be careful while your doing this.
dont toast your electrical
Old Dec 12, 2006 | 01:21 AM
im gonna do some research on it first try and find a diagram with the colors or something. im not gonna cut the wires from the stock plug im gonna use those splice into clips that you basically crimp into the line. hopefully i can find something
