DOES THE STOCK DELCO STEREO HAVE PRE-AMPS?
Old Mar 21, 2008 | 07:03 PM
Scooterewski's Avatar
Scooterewski is an unknown quantity at this point
Default DOES THE STOCK DELCO STEREO HAVE PRE-AMPS?
dOES ANYONE KNOW IF THE STOCK DELCO CD HEAD UNIT HAS PRE-AMPS? I HAVE THE REDUNDANT STEERING WHEEL RADIO CONTROLS AND DON'T NECESSARILY WANT TO CHANGE THE HEAD UNIT, BUT I WANNA HOOK UP MY SUB AND AMP.
Old Mar 21, 2008 | 07:04 PM
Default RE: DOES THE STOCK DELCO STEREO HAVE PRE-AMPS?
CAPS much??
No, there are no additional outputs from the stock head unit.
Old Mar 21, 2008 | 07:06 PM
Ooops...Is there any way to wire up an amp w/out them? Maybe splice some rca's into the rear speakers? Or not a good idea?
Old Mar 21, 2008 | 07:13 PM
You would need a line out converter (I think that is what it is called)...
Old Mar 21, 2008 | 07:15 PM
Sweet....Thanks
Old Mar 21, 2008 | 09:11 PM
hillbillyinOhio's Avatar
Kyle, you are right on! If you need the wire codes for what to splice into, check out my sticky on the top of the av forum!
Old Mar 22, 2008 | 12:23 PM
nice info hillbillyinohio....alot of info on that thread!!!
Old Mar 22, 2008 | 03:23 PM
drperry's Avatar
Doesn't sound as good, apparently, but you can use the High Input connections on your amp... It's made to be wired into the speaker lines.... If your amp has it.
Old Mar 23, 2008 | 09:30 AM
I couldn't find a high input plug for my amp...it has the high input on the amp, just can't find it anywhere. I ended up buying a line out converter.. to my surprise they had it at Wal-Mart. hookin it up soon....maybe later today
Old Mar 23, 2008 | 08:51 PM
Butts's Avatar
Butts is an unknown quantity at this point
I use an Audio Control 3.1. I've got the line level in from the fronts. 3.1 runs a JBL Cs 200.1 and a a/d/s P440. Everything works great except I just blew the front speakers. The 3.1 is nice due to it being a line driver, EQ, and line converter all in one.
Another option would be to buy a deck that can use a module that lets you use the steering wheel controls, Alpine sells this option.
