does it works with the oem head?
Old Feb 11, 2008 | 02:39 PM
burak sozer's Avatar
burak sozer is an unknown quantity at this point
Default does it works with the oem head?
I have a problem with my oem head, it doesnt reads cd untill the car warms up, I guess the reader of cd player out of allign. Can I just use this item to bypass oum reader? ( I have wood covering on dash panels, therefore its not easy to replace head unit.)
http://www.circuitcity.com/ssm/Pione...oductDetail.do
Would it work just by hooking it up to anntena ?
Old Feb 11, 2008 | 03:21 PM
WhiteTie BlackJacket's Avatar
WhiteTie BlackJacket is an unknown quantity at this point
Default RE: does it works with the oem head?
When you say wood covering do you mean something aftermarket or stock? If its stock its very easy to take off, theres a few screws you take out and then just pull it off.
Old Feb 11, 2008 | 03:32 PM
As you can see from the picture, this is aftermarket part, but covered all arround.
I do have on 2din dvd player w/6,5' tft screen, due to keep wood on dash im keeping it out.
[IMG]local://upfiles/8441/8F9C3CE198674FF6BC8FB9CFE4B4534F.jpg[/IMG]
Old Feb 11, 2008 | 05:39 PM
Jharper's Avatar
Jharper is infamous around these partsJharper is infamous around these parts
i would just cut the wood part you dont need after a new deck install, that would be alot better than a cd changer, you will have better sound quality as well if you dont have OEM radio
Old Feb 11, 2008 | 06:16 PM
That wood is just in place of the stock trim, so you could still put in an aftermarket deck.
er0ck273
Mar 6, 2015 03:54 PM
manekDC2_
Nov 5, 2010 02:55 AM
Mikes1Addiction
Jan 12, 2007 02:08 PM
paragod6801
Jun 6, 2006 04:13 AM
