filter
Old Dec 8, 2006 | 11:50 PM
rabbit0102030's Avatar
rabbit0102030 is an unknown quantity at this point
Default RE: filter
Taking turns their guys?! LOL
Old Dec 9, 2006 | 12:39 PM
FImports's Avatar
FImports is an unknown quantity at this point
Default RE: filter
where do yo connect the noise filter if the noise is coming from the alternator
Old Dec 9, 2006 | 01:15 PM
hillbillyinOhio's Avatar
Default RE: filter
first you need to address the question I asked you. the noise might not be from the alternator.
Old Dec 9, 2006 | 03:53 PM
blazinloud's Avatar
Default RE: filter
power wire ran beside the rca maybe......shouldnt they be on opposite sides
Old Dec 9, 2006 | 04:52 PM
mikeywaynebygod's Avatar
mikeywaynebygod is an unknown quantity at this point
Default RE: filter
bah, i've never had that problem. sounds weird, though. maybe try a ground loop isolator?
Old Dec 9, 2006 | 06:14 PM
Default RE: filter
try a new ground for radio. as a test,run a wire outside of the car to the negative terminal on the battery. hook that up to the ground on the deck. see if that helps. if not, look at all the wiring and see if anything is bare wire and let us know what you found.
Old Dec 9, 2006 | 09:11 PM
jagblazer01's Avatar
Default RE: filter
i have that problem sometimes.....i just adjust the RCA's a little bit on my amps and problem solved
Old Dec 10, 2006 | 01:00 AM
Binz316's Avatar
Binz316 is an unknown quantity at this point
Default RE: filter
my trucks am reception is horrible when the engine is running, but /w the engine off crystal clear. I have numerous shops look at it and they said perhaps a diode was leaking? interference, but why only in the am stations
Old Dec 10, 2006 | 01:03 AM
Default RE: filter
they are different parts of the board. go to an auto parts store and get an antenna booster. cost you probably 20 bucks, am and fm are totally improved. def worth the 20 bucks.
Old Dec 10, 2006 | 02:01 AM
Binz316's Avatar
Default RE: filter
hillbilly, how do those attach?
